Up to 20% off select tools
Samsung TL220 Power Button Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
90
All Time:
857
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
Introduction
Go to step 1 ↓
All you need for this guide is the will to fix your camera. Enjoy!
    1. Samsung TL220 Power Button Replacement, Power Button: step 1, image 1 of 3 Samsung TL220 Power Button Replacement, Power Button: step 1, image 2 of 3 Samsung TL220 Power Button Replacement, Power Button: step 1, image 3 of 3
      • Check for debris and dust around the power button to make sure it's clean.
      • If dust is absent, then begin with unscrewing the seven outside shell 4 mm Philips screws with the Philips screw driver.
      • Now carefully pry open the back casing with the ifixit plastic opening tool.
      Ask FixBot
    2. Samsung TL220 Power Button Replacement: step 2, image 1 of 2 Samsung TL220 Power Button Replacement: step 2, image 2 of 2
      • Now that you have the back casing off, gently remove the LCD screen from the camera.
      • Next unscrew the three 4 mm Philips screws on the back panel with the same screw driver(See image).
      Ask FixBot
    3. Samsung TL220 Power Button Replacement: step 3, image 1 of 2 Samsung TL220 Power Button Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Unclip the four connecters that hold down the orange copper film strips with the plastic opening tool.
      • Then carefully pull out the three film strips with the ifixit tweezers.
      Ask FixBot
    4. Samsung TL220 Power Button Replacement: step 4, image 1 of 1
      • Remove the 4 mm Philip screw located above the center film strip with the Philips screw driver. This will allow the top frame to come loose to take off.
      Ask FixBot
    5. Samsung TL220 Power Button Replacement: step 5, image 1 of 1
      • Then pull back the black claw located at the bottom right of the camera, to the right with the plastic opening tool. This holds the main plate down.
      Ask FixBot
    6. Samsung TL220 Power Button Replacement: step 6, image 1 of 1
      • Slowly lift with your fingers, the top frame of the camera to get to the power button.
      Ask FixBot
    7. Samsung TL220 Power Button Replacement: step 7, image 1 of 1
      • Replace power button with new one.
      Ask FixBot
2 other people completed this guide.
Author
with
chelsa
358 Reputation
3 Guides authored
3 Tech Girls Member of 3 Tech Girls
Community
2 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 90
All Time: 857
