Up to 20% off select tools
Samsung TL220 LCD Screen Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
92
All Time:
1,304
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Samsung TL220 LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
      • Begin with unscrewing the seven outer screws on the camera. There is one on each corner and then three at the bottom.
      Ask FixBot
    2. Samsung TL220 LCD Screen Replacement: step 2, image 1 of 1
      • Now carefully pry open the back casing with the ifixit plastic opening tool.
      Ask FixBot
    3. Samsung TL220 LCD Screen Replacement: step 3, image 1 of 1
      • When the back casing is off, gently move the LCD screen to the side.
      • And then remove the three inner screws to remove the inside case.
      Ask FixBot
    4. Samsung TL220 LCD Screen Replacement: step 4, image 1 of 1
      • Unclip the four connectors that hold down the orange copper film strips.
      • Then carefully pull out the three film strips with the ifixit plastic opening tool.
      Ask FixBot
    5. Samsung TL220 LCD Screen Replacement: step 5, image 1 of 2 Samsung TL220 LCD Screen Replacement: step 5, image 2 of 2
      • Remove the screw located above the center film strip. This holds the top frame in place.
      Ask FixBot
    6. Samsung TL220 LCD Screen Replacement: step 6, image 1 of 1
      • Unclip the four connectors to release the film strips.
      Ask FixBot
    7. Samsung TL220 LCD Screen Replacement: step 7, image 1 of 1
      • Next unclamp the connector to release the film strip and then you can replace your LCD screen.
      Ask FixBot
2 other people completed this guide.
Author
with
Lesley
170 Reputation
1 Guide authored
3 Tech Girls Member of 3 Tech Girls
Community
2 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 92
All Time: 1,304
