Up to 20% off select tools
Samsung TL220 Battery Spring Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
108
All Time:
1,337
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your Samsung TL220 is rattling from the inside of the camera, use this guide to replace the battery spring and hold the camera battery in place.
The spring inside the camera is responsible for holding the battery in place. If the spring got loose or no longer supports the battery. It can cause damage to the inside of the camera.
Make sure the camera is completely turned off before starting.
    1. Samsung TL220 Battery Spring Replacement, Battery Spring Replacement: step 1, image 1 of 2 Samsung TL220 Battery Spring Replacement, Battery Spring Replacement: step 1, image 2 of 2
      • Begin by unscrewing all seven 4 mm phillip's screws located on the outside of the camera.
      • Using the plastic opening tool carefully pry open the camera, lifting the back casing off.
      Ask FixBot
    2. Samsung TL220 Battery Spring Replacement: step 2, image 1 of 2 Samsung TL220 Battery Spring Replacement: step 2, image 2 of 2
      • Now that you have the back casing off, gently move the LCD screen from the camera to the right and lay it facing down on the table.
      • Next unscrew the three 4 mm Philips screws on the back panel with the same screw driver.
      Ask FixBot
    3. Samsung TL220 Battery Spring Replacement: step 3, image 1 of 2 Samsung TL220 Battery Spring Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Unclip the four connectors with the plastic opening tool which holds down the orange film strips.
      • Gently with the tweezers remove the four orange film strips from the connectors.
      Ask FixBot
    4. Samsung TL220 Battery Spring Replacement: step 4, image 1 of 2 Samsung TL220 Battery Spring Replacement: step 4, image 2 of 2
      • Once the orange film strips have been released from the connectors, unscrew the Phillips 4 mm silver screw which holds down the top of the camera's frame.
      • With your fingers gently push up the camera's top frame. Once the camera's top frame is off you can than gently remove the camera's front casing off, as well.
      Ask FixBot
    5. Samsung TL220 Battery Spring Replacement: step 5, image 1 of 2 Samsung TL220 Battery Spring Replacement: step 5, image 2 of 2
      • Flip the entire camera over so that the lenses are facing upward with the LCD screen showing to the side.
      • Now remove the silver case, seen demonstrated in the picture.
      Ask FixBot
    6. Samsung TL220 Battery Spring Replacement: step 6, image 1 of 1
      • After all the parts are disassembled, you will reach the spring part of the camera.
      Ask FixBot
2 other people completed this guide.
Author
with
chelsa
358 Reputation
3 Guides authored
3 Tech Girls Member of 3 Tech Girls
Community
2 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 108
All Time: 1,337
