Samsung TFT Color YP-T7J Motherboard Replacement
    1. Samsung TFT Color YP-T7J Motherboard Replacement, The Back Cover: step 1, image 1 of 2 Samsung TFT Color YP-T7J Motherboard Replacement, The Back Cover: step 1, image 2 of 2
      • Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
      Ask FixBot
    2. Samsung TFT Color YP-T7J Motherboard Replacement: step 2, image 1 of 2 Samsung TFT Color YP-T7J Motherboard Replacement: step 2, image 2 of 2
      • Remove the screw on each side of the device using a Phillips head screwdriver.
      Ask FixBot
    3. Samsung TFT Color YP-T7J Motherboard Replacement: step 3, image 1 of 3 Samsung TFT Color YP-T7J Motherboard Replacement: step 3, image 2 of 3 Samsung TFT Color YP-T7J Motherboard Replacement: step 3, image 3 of 3
      • Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
      • Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
      Ask FixBot
    1. Samsung TFT Color YP-T7J Motherboard Replacement, The Battery: step 4, image 1 of 2 Samsung TFT Color YP-T7J Motherboard Replacement, The Battery: step 4, image 2 of 2
      • Once the back cover has been removed the battery will be visible.
      • Pry the battery from the device.
      • NOTE: The battery should still be connected to the device
      Ask FixBot
    2. Samsung TFT Color YP-T7J Motherboard Replacement: step 5, image 1 of 2 Samsung TFT Color YP-T7J Motherboard Replacement: step 5, image 2 of 2
      • Unplug the battery connecting cables.
      • NOTE: The battery now should be free from all connections to the device.
      Ask FixBot
    1. Samsung TFT Color YP-T7J Motherboard Replacement, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: step 6, image 1 of 3 Samsung TFT Color YP-T7J Motherboard Replacement, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: step 6, image 2 of 3 Samsung TFT Color YP-T7J Motherboard Replacement, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: step 6, image 3 of 3
      • Once the battery has been removed you can see the motherboard.
      • Unscrew 4 screws on the metal docket using a Phillips head screw driver.
      • The USB connector can now be taken off of the device.
      Ask FixBot
    1. Samsung TFT Color YP-T7J Motherboard Replacement, The Front Cover: step 7, image 1 of 2 Samsung TFT Color YP-T7J Motherboard Replacement, The Front Cover: step 7, image 2 of 2
      • Using the philips screwdriver, remove the two screws on the mother board.
      Ask FixBot
    2. Samsung TFT Color YP-T7J Motherboard Replacement: step 8, image 1 of 3 Samsung TFT Color YP-T7J Motherboard Replacement: step 8, image 2 of 3 Samsung TFT Color YP-T7J Motherboard Replacement: step 8, image 3 of 3
      • Place the pry tool in-between the front cover and mother board.
      • Gently separate the front cover.
      Ask FixBot
    3. Samsung TFT Color YP-T7J Motherboard Replacement: step 9, image 1 of 1
      • After opening the front cover you will see and electric ribbon connecting the buttons to the mother board.
      Ask FixBot
    4. Samsung TFT Color YP-T7J Motherboard Replacement: step 10, image 1 of 2 Samsung TFT Color YP-T7J Motherboard Replacement: step 10, image 2 of 2
      • CAUTION: Do not rip the electric ribbon from the mother board.
      • Carefully flip up the plastic lip that holds the electric ribbon to the board.
      Ask FixBot
    1. Samsung TFT Color YP-T7J Motherboard Replacement, Motherboard: step 11, image 1 of 2 Samsung TFT Color YP-T7J Motherboard Replacement, Motherboard: step 11, image 2 of 2
      • Remove the 3 screws located around the motherboard. 2 screws are located on the left side and1 screw is located on the right side.
      • NOTE:The orientation of the second picture is screen side down!
      Ask FixBot
    2. Samsung TFT Color YP-T7J Motherboard Replacement: step 12, image 1 of 2 Samsung TFT Color YP-T7J Motherboard Replacement: step 12, image 2 of 2
      • The motherboard should be loose from the middle casing.
      • Gently pull the motherboard away from the middle casing
      • The device should now be in multiple parts.
      Ask FixBot
Dylan Peters
409 Reputation
4 Guides authored
Clemson, Team 14-8, Benson Fall 2013 Member of Clemson, Team 14-8, Benson Fall 2013
CLEM-BENSON-F13S14G8
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 21
Past 30 Days: 102
All Time: 907
