Up to 20% off select tools
Samsung T139 SIM Card Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
21
Past 30 Days:
93
All Time:
2,086
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the SIM card in your Samsung T139.
    1. Samsung T139 SIM Card Replacement, Remove Back Cover: step 1, image 1 of 3 Samsung T139 SIM Card Replacement, Remove Back Cover: step 1, image 2 of 3 Samsung T139 SIM Card Replacement, Remove Back Cover: step 1, image 3 of 3
      • Power off your phone before beginning disassembly
      • Apply pressure to the back cover and slide towards the base
      Ask FixBot
    2. Samsung T139 SIM Card Replacement, Remove Battery: step 2, image 1 of 2 Samsung T139 SIM Card Replacement, Remove Battery: step 2, image 2 of 2
      • With a plastic opening tool, lift and remove the battery
      Ask FixBot
    1. Samsung T139 SIM Card Replacement, SIM Card: step 3, image 1 of 3 Samsung T139 SIM Card Replacement, SIM Card: step 3, image 2 of 3 Samsung T139 SIM Card Replacement, SIM Card: step 3, image 3 of 3
      • Using your thumb, slide SIM card out toward the base of the phone
      • The SIM card is a thin plastic component and can easily break under excessive force. Press and slide as gently as possible
      Ask FixBot
Author
with
Reagan May
588 Reputation
5 Guides authored
Michigan Tech, Team 1-1, Lauer Fall 2014 Member of Michigan Tech, Team 1-1, Lauer Fall 2014
MTU-LAUER-F14S1G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 93
All Time: 2,086
