Samsung T139 Pad Buttons Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
10
Past 30 Days:
82
All Time:
798
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace a worn out button pad on your Samsung T139.
Parts
Tools
    1. Samsung T139 Pad Buttons Replacement, Remove Back Cover: step 1, image 1 of 3 Samsung T139 Pad Buttons Replacement, Remove Back Cover: step 1, image 2 of 3 Samsung T139 Pad Buttons Replacement, Remove Back Cover: step 1, image 3 of 3
      • Power off your phone before beginning disassembly
      • Apply pressure to the back cover and slide towards the base
      Ask FixBot
    2. Samsung T139 Pad Buttons Replacement, Remove Battery: step 2, image 1 of 2 Samsung T139 Pad Buttons Replacement, Remove Battery: step 2, image 2 of 2
      • With a plastic opening tool, lift and remove the battery
      Ask FixBot
    1. Samsung T139 Pad Buttons Replacement, Remove Screws: step 3, image 1 of 2 Samsung T139 Pad Buttons Replacement, Remove Screws: step 3, image 2 of 2
      • Remove the four Phillips 1.0mm #0 screws
      Ask FixBot
    2. Samsung T139 Pad Buttons Replacement, Remove Black Plastic Cover: step 4, image 1 of 3 Samsung T139 Pad Buttons Replacement, Remove Black Plastic Cover: step 4, image 2 of 3 Samsung T139 Pad Buttons Replacement, Remove Black Plastic Cover: step 4, image 3 of 3
      • Using the plastic opening tool, work around the edge of the black plastic cover until it pops off
      Ask FixBot
    3. Samsung T139 Pad Buttons Replacement, Remove Side Buttons: step 5, image 1 of 2 Samsung T139 Pad Buttons Replacement, Remove Side Buttons: step 5, image 2 of 2
      • Remove side buttons by lifting them off the board
      Ask FixBot
    4. Samsung T139 Pad Buttons Replacement, Remove Circuit Board: step 6, image 1 of 1
      • Lift circuit board up gently
      • Be careful to not pull ribbon cord apart when removing
      Ask FixBot
    5. Samsung T139 Pad Buttons Replacement, Remove Button Pad: step 7, image 1 of 2 Samsung T139 Pad Buttons Replacement, Remove Button Pad: step 7, image 2 of 2
      • Lift away button pad
      Ask FixBot
Reagan May
588 Reputation
5 Guides authored
Michigan Tech, Team 1-1, Lauer Fall 2014 Member of Michigan Tech, Team 1-1, Lauer Fall 2014
MTU-LAUER-F14S1G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 82
All Time: 798
