Samsung T139 Camera Lens Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
92
All Time:
631
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If you are having problems with the camera on your Samsung T139, use this guide to replace it.
Tools
    1. Samsung T139 Camera Lens Replacement, Remove Back Cover: step 1, image 1 of 3 Samsung T139 Camera Lens Replacement, Remove Back Cover: step 1, image 2 of 3 Samsung T139 Camera Lens Replacement, Remove Back Cover: step 1, image 3 of 3
      • Power off your phone before beginning disassembly
      • Apply pressure to the back cover and slide towards the base
      Ask FixBot
    2. Samsung T139 Camera Lens Replacement, Remove Battery: step 2, image 1 of 2 Samsung T139 Camera Lens Replacement, Remove Battery: step 2, image 2 of 2
      • With a plastic opening tool, lift and remove the battery
      Ask FixBot
    1. Samsung T139 Camera Lens Replacement, Remove Screw Stickers: step 3, image 1 of 2 Samsung T139 Camera Lens Replacement, Remove Screw Stickers: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Using the tweezers, remove the two rubber soles that cover the panel screws
      Ask FixBot
    2. Samsung T139 Camera Lens Replacement, Remove Screws: step 4, image 1 of 2 Samsung T139 Camera Lens Replacement, Remove Screws: step 4, image 2 of 2
      • Remove two Phillips 1.0mm #0 screws
      Ask FixBot
    3. Samsung T139 Camera Lens Replacement, Remove Face Plate: step 5, image 1 of 3 Samsung T139 Camera Lens Replacement, Remove Face Plate: step 5, image 2 of 3 Samsung T139 Camera Lens Replacement, Remove Face Plate: step 5, image 3 of 3
      • With the plastic opening tool, work around the face plate until it pops off
      Ask FixBot
    4. Samsung T139 Camera Lens Replacement, Remove Camera Lens: step 6, image 1 of 2 Samsung T139 Camera Lens Replacement, Remove Camera Lens: step 6, image 2 of 2
      • Apply pressure to the lens, pushing it out the back
      Ask FixBot
2 other people completed this guide.
Reagan May
588 Reputation
5 Guides authored
Michigan Tech, Team 1-1, Lauer Fall 2014 Member of Michigan Tech, Team 1-1, Lauer Fall 2014
MTU-LAUER-F14S1G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 92
All Time: 631
