Samsung Stratosphere Flex Cable Replacement
    1. Samsung Stratosphere Flex Cable Replacement, Battery: step 1, image 1 of 1
      • Using your fingers, pry along the groove at the top of the phone.
      • Pull back on the rear casing until it comes free from the device.
      • The casing will make a cracking sound as it is removed.
      Ask FixBot
    2. Samsung Stratosphere Flex Cable Replacement: step 2, image 1 of 1
      • With your fingers, pry from the bottom of the battery to loosen it.
      • Lift away to remove the battery from the phone.
      Ask FixBot
    1. Samsung Stratosphere Flex Cable Replacement, Motherboard: step 3, image 1 of 1
      • Locate the red and white sim card located above the battery housing.
      • Remove the sim card by sliding it downwards from its slot with your fingers.
      Ask FixBot
    2. Samsung Stratosphere Flex Cable Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the seven silver 3mm screws securing the rear panel using the Phillips #000 screwdriver.
      • Once loosened, some screws may get stuck in the casing. Use tweezers to remove them.
      Ask FixBot
    3. Samsung Stratosphere Flex Cable Replacement: step 5, image 1 of 1
      • Pry around the rear panel with a plastic opening tool to loosen it.
      • Prying too deeply may damage delicate components inside the phone.
      • Remove the rear panel from the phone with your fingers.
      Ask FixBot
    4. Samsung Stratosphere Flex Cable Replacement: step 6, image 1 of 1
      • Remove the four black 3mm screws securing the motherboard with the Phillips #000 screwdriver.
      Ask FixBot
    5. Samsung Stratosphere Flex Cable Replacement: step 7, image 1 of 2 Samsung Stratosphere Flex Cable Replacement: step 7, image 2 of 2
      • Locate the flex cable attachment at the tab with a green arrow printed on top.
      • Pry from the side the arrow is pointing with your fingers.
      • The cable will audibly snap as it is removed from its attachment.
      • Let the cable hang loosely to the side of the phone.
      Ask FixBot
    6. Samsung Stratosphere Flex Cable Replacement: step 8, image 1 of 1
      • Pull the motherboard up from the side opposite the loose flex cable.
      • If necessary, use a plastic opening tool to separate the motherboard from the key pad underneath.
      • Lift to remove the motherboard from the device.
      Ask FixBot
    1. Samsung Stratosphere Flex Cable Replacement, Front Camera: step 9, image 1 of 1
      • Insert a plastic opening tool into any side of the phone case to separate the keyboard from the rear panel.
      • Pry the keyboard away from the casing with the plastic opening tool.
      • The keyboard should come off with almost no force at all.
      Ask FixBot
    2. Samsung Stratosphere Flex Cable Replacement: step 10, image 1 of 1
      • Remove the 7 silver 2mm screws attaching the silver metal plate to the rear panel with the Phillips #000 Screwdriver.
      Ask FixBot
    3. Samsung Stratosphere Flex Cable Replacement: step 11, image 1 of 1
      • Use the plastic opening tool to carefully loosen the golden metal plate.
      • The golden metal plate is stuck to the rear panel with a strong adhesive, so a moderate amount of force may be needed.
      Ask FixBot
    4. Samsung Stratosphere Flex Cable Replacement: step 12, image 1 of 1
      • Lift the gold plate with your fingers, repositioning it to slide through the keyboard casing underneath.
      • Carefully take off the keyboard casing with your fingers.
      • The golden metal plate should fit through the wide slot of the casing.
      Ask FixBot
    5. Samsung Stratosphere Flex Cable Replacement: step 13, image 1 of 1
      • Slide the silver metal plate down and away from the to the flex cable and gold metal plate.
      • The metal plate is attached to springs that offer a small amount of resistance, so it will snap into place.
      Ask FixBot
    6. Samsung Stratosphere Flex Cable Replacement: step 14, image 1 of 1
      • Unscrew the 4 black 3mm screws from the rear panel with the Phillips #000 Screwdriver.
      Ask FixBot
    7. Samsung Stratosphere Flex Cable Replacement: step 15, image 1 of 2 Samsung Stratosphere Flex Cable Replacement: step 15, image 2 of 2
      • Insert the plastic opening tool into the groove at the top of the rear panel.
      • Firmly slide the plastic opening tool all around the rear panel. The panel will audibly snap as it comes apart.
      • These 2 pieces are attached well, so a significant amount of force is needed to separate them.
      Ask FixBot
    8. Samsung Stratosphere Flex Cable Replacement: step 16, image 1 of 1
      • Lift the flex cable and position it so the part containing the metal plate can come free.
      • Pull the part containing the metal plate away from the rest of the rear panel.
      Ask FixBot
    9. Samsung Stratosphere Flex Cable Replacement: step 17, image 1 of 2 Samsung Stratosphere Flex Cable Replacement: step 17, image 2 of 2
      Buy
      • Use tweezers to loosen the front-facing camera from the plastic casing.
      • Pull the black rectangular piece, attached to the front facing camera, away from the rear panel.
      Ask FixBot
    1. Samsung Stratosphere Flex Cable Replacement, Flex Cable: step 18, image 1 of 1
      • Carefully peel the blue tape from the bottom of the flex cable and set it aside.
      Ask FixBot
    2. Samsung Stratosphere Flex Cable Replacement: step 19, image 1 of 2 Samsung Stratosphere Flex Cable Replacement: step 19, image 2 of 2
      • Use one of the plastic opening tools to loosen the flex cable from its central housing.
      • Pull lightly on the flex cable to free it from the housing.
      • The cable may audibly snap as it is freed from its attachment.
      Ask FixBot
    3. Samsung Stratosphere Flex Cable Replacement: step 20, image 1 of 1
      Buy
      • Use tweezers to loosen the flex cable and speaker from the bottom of the phone.
      • Pull upward with the tweezers and the flex cable will come loose.
      • The flex cable will come free with the front-facing camera attached. In order to remove the front-facing camera, see our guide here.
      Ask FixBot
2 other people completed this guide.
Jonathan Oyan
624 Reputation
1 Guide authored
Cal Poly, Team 11-32, Amido Fall 2013 Member of Cal Poly, Team 11-32, Amido Fall 2013
CPSU-AMIDO-F13S11G32
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 108
All Time: 1,884
