Up to 20% off select tools
Samsung Stratosphere Battery Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
84
All Time:
1,732
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show you how to remove the back panel of your phone and replace the battery.
    1. Samsung Stratosphere Battery Replacement, Battery: step 1, image 1 of 1
      • Using your fingers, pry along the groove at the top of the phone.
      • Pull back on the rear casing until it comes free from the device.
      • The casing will make a cracking sound as it is removed.
      Ask FixBot
    2. Samsung Stratosphere Battery Replacement: step 2, image 1 of 1
      • With your fingers, pry from the bottom of the battery to loosen it.
      • Lift away to remove the battery from the phone.
      Ask FixBot
3 other people completed this guide.
Author
with
Angelica Macrohon
267 Reputation
2 Guides authored
Cal Poly, Team 11-32, Amido Fall 2013 Member of Cal Poly, Team 11-32, Amido Fall 2013
CPSU-AMIDO-F13S11G32
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 84
All Time: 1,732
