Up to 20% off select tools
Samsung Solstice SIM Card Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
85
All Time:
835
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
If you plan on using your Samsung Solstice in your daily life, you will need phone service, which requires installing a SIM card. Luckily the task of installing a SIM card is very simple.
    1. Samsung Solstice SIM Card Replacement, Remove the back cover: step 1, image 1 of 2 Samsung Solstice SIM Card Replacement, Remove the back cover: step 1, image 2 of 2
      • Remove the back cover by sliding the cover off of the phone by pushing it upwards, in the direction of the small arrow on the back cover.
      • Set the cover off to the side once you have removed it.
      Ask FixBot
    2. Samsung Solstice SIM Card Replacement, Removing existing SIM Card: step 2, image 1 of 3 Samsung Solstice SIM Card Replacement, Removing existing SIM Card: step 2, image 2 of 3 Samsung Solstice SIM Card Replacement, Removing existing SIM Card: step 2, image 3 of 3
      • Locate the SIM Card slot directly above the battery and below the phone camera
      • Place your thumb on the SIM Card in the slot, press down gently and slide the card away from the slot, until it comes out of the slot entirely
      Ask FixBot
    3. Samsung Solstice SIM Card Replacement, Set SIM Card aside: step 3, image 1 of 1
      • Once you have removed the SIM card, set it aside from the phone.
      Ask FixBot
Author
with
Colton Glyder
301 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 85
All Time: 835
