Up to 20% off select tools
Samsung Solstice Battery Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
84
All Time:
960
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Parts
Tools
Introduction
Go to step 1 ↓
You may need to replace the battery in your Samsung Solstice for a number of reasons. Perhaps the battery is damaged, or perhaps the phone is frozen and you need to remove the battery to reset it.
    1. Samsung Solstice Battery Replacement, Removing the back cover: step 1, image 1 of 3 Samsung Solstice Battery Replacement, Removing the back cover: step 1, image 2 of 3 Samsung Solstice Battery Replacement, Removing the back cover: step 1, image 3 of 3
      • Gently slide the cover off of the phone by pushing it upwards, in the direction of the small arrow on the back cover.
      • Set the cover off to the side once you have removed it.
      Ask FixBot
    2. Samsung Solstice Battery Replacement, Removing the battery: step 2, image 1 of 3 Samsung Solstice Battery Replacement, Removing the battery: step 2, image 2 of 3 Samsung Solstice Battery Replacement, Removing the battery: step 2, image 3 of 3
      • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
      • Wedge a plastic opening tool in between the rear end of the battery and the plastic frame.
      • Pry the battery up out of its recess and away from the phone.
      Ask FixBot
Author
with
Colton Glyder
301 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 84
All Time: 960
