Up to 20% off select tools
Samsung SmartThings Hub Power Port Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
96
All Time:
1,920
Comments: 0
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Difficult
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
This guide outlines a procedure for completely removing and replacing a non-functioning power port on the motherboard of the Samsung SmartThings Hub.
    1. Samsung SmartThings Hub Power Port  Replacement, Power Port: step 1, image 1 of 1
      • To open your device, gently slide the grey bottom cover in the direction of the arrow as shown.
      Ask FixBot
    2. Samsung SmartThings Hub Power Port  Replacement: step 2, image 1 of 3 Samsung SmartThings Hub Power Port  Replacement: step 2, image 2 of 3 Samsung SmartThings Hub Power Port  Replacement: step 2, image 3 of 3
      • Make sure the batteries are removed before attempting disassembly.
      • Using your Phillips #1 screwdriver, remove the four visible 12.5mm screws.
      • Next, either peel up the longer of the two stickers or punch a hole with the tip of your screwdriver to access the fifth 12.5mm screw.
      Ask FixBot
    3. Samsung SmartThings Hub Power Port  Replacement: step 3, image 1 of 3 Samsung SmartThings Hub Power Port  Replacement: step 3, image 2 of 3 Samsung SmartThings Hub Power Port  Replacement: step 3, image 3 of 3
      • Once all five screws are removed, split the casing apart by applying gentle upwards pressure against the positive terminals in the battery compartment.
      Ask FixBot
    4. Samsung SmartThings Hub Power Port  Replacement: step 4, image 1 of 2 Samsung SmartThings Hub Power Port  Replacement: step 4, image 2 of 2
      • To remove the motherboard, grip the USB port and the Ethernet port. Lift up, then slide towards the front of the device to release the motherboard from the black retaining clip shown on the right.
      Ask FixBot
    5. Samsung SmartThings Hub Power Port  Replacement: step 5, image 1 of 3 Samsung SmartThings Hub Power Port  Replacement: step 5, image 2 of 3 Samsung SmartThings Hub Power Port  Replacement: step 5, image 3 of 3
      • Place the motherboard on a clean, flat surface.
      • Preheat your soldering iron. The power port has three points of connection to the motherboard (pictured below). Using your soldering iron, apply heat to each solder joint in turn while pulling the power port away from the board.
      • Soldering irons can reach temperatures of over 500 degrees. Watch your fingers!
      • For more information on soldering refer to How to Solder and Desolder Connections
      Ask FixBot
    6. Samsung SmartThings Hub Power Port  Replacement: step 6, image 1 of 2 Samsung SmartThings Hub Power Port  Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers, remove the desoldered power port from the motherboard.
      Ask FixBot
5 other people completed this guide.
Author
with
Erin
494 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 96
All Time: 1,920
