Samsung SmartCam HD Speaker Replacement
  1. Samsung SmartCam HD Speaker Replacement, Speaker: step 1, image 1 of 3 Samsung SmartCam HD Speaker Replacement, Speaker: step 1, image 2 of 3 Samsung SmartCam HD Speaker Replacement, Speaker: step 1, image 3 of 3
    • Remove the mount.
    • Use the mount replacement guide if necessary to take the mount off.
    Ask FixBot
  2. Samsung SmartCam HD Speaker Replacement: step 2, image 1 of 2 Samsung SmartCam HD Speaker Replacement: step 2, image 2 of 2
    • Unscrew the screw next to the mount holder.
    Ask FixBot
  3. Samsung SmartCam HD Speaker Replacement: step 3, image 1 of 3 Samsung SmartCam HD Speaker Replacement: step 3, image 2 of 3 Samsung SmartCam HD Speaker Replacement: step 3, image 3 of 3
    • At the bottom of the SmartCam there is a tab that you can stick a spudger r in.
    • Once the spudger is in, gently pry it open.
    • Work your way around the SmartCam with the spudger loosing 8 clips.
    • Buttons may fall out, but can be reinserted easily.
    Ask FixBot
  4. Samsung SmartCam HD Speaker Replacement: step 4, image 1 of 2 Samsung SmartCam HD Speaker Replacement: step 4, image 2 of 2
    • Gently remover the cover.
    • Beware of the wires connected to the camera.
    Ask FixBot
  5. Samsung SmartCam HD Speaker Replacement: step 5, image 1 of 3 Samsung SmartCam HD Speaker Replacement: step 5, image 2 of 3 Samsung SmartCam HD Speaker Replacement: step 5, image 3 of 3
    • The speaker should be attached to the cover with red and black wires going to the main board.
    • Unscrew the two screws holding the speaker in place.
    Ask FixBot
  6. Samsung SmartCam HD Speaker Replacement: step 6, image 1 of 3 Samsung SmartCam HD Speaker Replacement: step 6, image 2 of 3 Samsung SmartCam HD Speaker Replacement: step 6, image 3 of 3
    • Gently take the speaker out of the cover.
    • Take out the red and black wires from a small plug-in on the main board.
    Ask FixBot
2 other people completed this guide.
Pranab Baidya
104 Reputation
1 Guide authored
UW Tacoma, Team S1-G1, Liner Summer 2017 Member of UW Tacoma, Team S1-G1, Liner Summer 2017
UWT-LINER-SU17S1G1
4 Members
6 Guides authored
1 Guide Comment
You mind giving speaker part number. I have the Samsung camera with the smaller speaker. Any ideas
frank scalise - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 887
