Samsung Series 9 NP900X4D-A03US Display Replacement
  1. Samsung Series 9 NP900X4D-A03US Display Replacement, Battery: step 1, image 1 of 2 Samsung Series 9 NP900X4D-A03US Display Replacement, Battery: step 1, image 2 of 2
    • Use the screwdriver to remove the ten 2.5mm Phillips #00 screws.
    • Use an iFixit opening tool to carefully remove the back panel from the laptop.
    Ask FixBot
  2. Samsung Series 9 NP900X4D-A03US Display Replacement: step 2, image 1 of 1
    • Remove the seven 0.5 mm Phillips #00 screws.
    Ask FixBot
  3. Samsung Series 9 NP900X4D-A03US Display Replacement: step 3, image 1 of 3 Samsung Series 9 NP900X4D-A03US Display Replacement: step 3, image 2 of 3 Samsung Series 9 NP900X4D-A03US Display Replacement: step 3, image 3 of 3
    • Lightly place some pressure into the highlighted cavity on the battery's outlet plug with a spudger.
    • Carefully remove the wires from the outlet plug.
    • Now you will be able to remove the battery from its place.
    Ask FixBot
  4. Samsung Series 9 NP900X4D-A03US Display Replacement, Display: step 4, image 1 of 2 Samsung Series 9 NP900X4D-A03US Display Replacement, Display: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, gently remove the adhesive surrounding the cover. At the same time, gently pry the cover off of the display using an iFixit opening tool.
    • Gently place the cover to the left, as a wire is still attached.
    Ask FixBot
  5. Samsung Series 9 NP900X4D-A03US Display Replacement: step 5, image 1 of 3 Samsung Series 9 NP900X4D-A03US Display Replacement: step 5, image 2 of 3 Samsung Series 9 NP900X4D-A03US Display Replacement: step 5, image 3 of 3
    • Use the Phillips #00 screwdriver to unscrew the four 2.5mm screws.
    • Gently remove the tabs from each corner.
    Ask FixBot
  6. Samsung Series 9 NP900X4D-A03US Display Replacement: step 6, image 1 of 2 Samsung Series 9 NP900X4D-A03US Display Replacement: step 6, image 2 of 2
    • Use the iFixit opening tool to detach the screen from the frame.
    • Slowly lay the screen down on the keyboard.
    • Be careful not to lift or tug on the display since a wire is still connected.
    Ask FixBot
  7. Samsung Series 9 NP900X4D-A03US Display Replacement: step 7, image 1 of 3 Samsung Series 9 NP900X4D-A03US Display Replacement: step 7, image 2 of 3 Samsung Series 9 NP900X4D-A03US Display Replacement: step 7, image 3 of 3
    • Using tweezers, slowly remove the connected wire from the display.
    • Gently remove the display from the device.
    Ask FixBot
John
139 Reputation
1 Guide authored
3 Guide Comments
Good day
Where can I buy the screen?
My laptop model number is NP900X4D-A01ZA
Your assistance will be highly appreciated
Kind regards
Rixongile Mathebula - Reply Share
is not easy to get that screen i think it needs a special screen
adolph sibomana - Reply Share
How Can I get that screen or any other related Screen ?
Morphat Gold - Reply Share
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 36
All Time: 2,811
