Samsung Series 5 UltraTouch Battery Replacement
Views: 28K
View statistics:
Past 24 Hours:
4
Past 7 Days:
32
Past 30 Days:
125
All Time:
28,149
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 14
14 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Easy
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Introduction
Go to step 1 ↓
This guide will show how to remove the covers from the underside of the laptop, remove the battery, and replace it with the new battery.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Samsung Series 5 UltraTouch Battery Replacement, Remove the Screws on the Back Cover: step 1, image 1 of 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Screws on the Back Cover: step 1, image 2 of 2
      • Power off the device. Remove the remaining screws holding the back cover in place:
      • Six 4.0 mm Phillips #00 screws.
      • Seven 6.7 mm Phillips #00 screws.
      Ask FixBot
    2. Samsung Series 5 UltraTouch Battery Replacement, Remove the Rubber Pads: step 2, image 1 of 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Rubber Pads: step 2, image 2 of 2
      • Remove the two rubber pads concealing the final bottom case screws.
      • Remove the two 4 mm Phillips #00 screws found under these pads.
      Ask FixBot
    3. Samsung Series 5 UltraTouch Battery Replacement, Remove the Back Cover: step 3, image 1 of 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Back Cover: step 3, image 2 of 2
      • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
      • Remove the entire rest of the back cover.
      Ask FixBot
    4. Samsung Series 5 UltraTouch Battery Replacement: step 4, image 1 of 2 Samsung Series 5 UltraTouch Battery Replacement: step 4, image 2 of 2
      • Remove the tape holding the wires in place.
      Ask FixBot
    5. Samsung Series 5 UltraTouch Battery Replacement: step 5, image 1 of 1
      • Remove the following Phillips 00 screws securing the battery:
      • Four 4.5 mm screws
      • Two 6.7 mm Phillips screws
      Ask FixBot
    6. Samsung Series 5 UltraTouch Battery Replacement, Remove the Battery: step 6, image 1 of 1
      • Pull the battery connector towards the battery to disconnect it.
      Ask FixBot
    7. Samsung Series 5 UltraTouch Battery Replacement: step 7, image 1 of 1
      • Remove the battery from the laptop.
      Ask FixBot
14 other people completed this guide.
Timothy
1,603 Reputation
5 Guides authored
USF Tampa, Team 16-3, Watkins Winter 2015 Member of USF Tampa, Team 16-3, Watkins Winter 2015
USFT-WATKINS-W15S16G3
4 Members
60 Guides authored
2 Guide Comments
I have one question.. does the laptop operate without the battery? I want to take it out and not replace it.. thanks for your time..Chris
Chris - Reply Share
If you have a computer connected to a power supply that will still allow it to work.
Ruben Guardado - Reply Share
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 125
All Time: 28,149
