Up to 20% off select tools
Samsung ST76 Front Panel Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
106
All Time:
1,072
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide can be used to replace any damaged front panels, access the lens, and other inner parts of the camera.
    1. Samsung ST76 Front Panel Replacement, Front Panel: step 1, image 1 of 3 Samsung ST76 Front Panel Replacement, Front Panel: step 1, image 2 of 3 Samsung ST76 Front Panel Replacement, Front Panel: step 1, image 3 of 3
      • Use a Phillips head screwdriver to remove 5 screws from the camera. There are 2 4mm screws on the left side, 2 2mm screws on the right side and 1 4mm screw on the bottom.
      • Do not mix the 5 screws; they are different sizes.
      Ask FixBot
    2. Samsung ST76 Front Panel Replacement: step 2, image 1 of 2 Samsung ST76 Front Panel Replacement: step 2, image 2 of 2
      • Use your fingers to pull front cover off.
      Ask FixBot
Author
with
Angela Fierst
376 Reputation
2 Guides authored
Marist, Team 1-6, Laflen Spring 2015 Member of Marist, Team 1-6, Laflen Spring 2015
MARS-LAFLEN-S15S1G6
2 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 106
All Time: 1,072
