Samsung ST150F Rear Panel Control Board Replacement
    1. Samsung ST150F Rear Panel Control Board Replacement, Outer Casing: step 1, image 1 of 3 Samsung ST150F Rear Panel Control Board Replacement, Outer Casing: step 1, image 2 of 3 Samsung ST150F Rear Panel Control Board Replacement, Outer Casing: step 1, image 3 of 3
      • Remove these screws from the camera using a phillips head screwdriver.
      Ask FixBot
    2. Samsung ST150F Rear Panel Control Board Replacement: step 2, image 1 of 1
      • Lay the camera down on the table and remove the metal shell from the front.
      Ask FixBot
    3. Samsung ST150F Rear Panel Control Board Replacement: step 3, image 1 of 1
      • Wedge a spudger/flathead screwdriver inside of the shell where the screws were to pry the shell off of the back.
      Ask FixBot
    4. Samsung ST150F Rear Panel Control Board Replacement: step 4, image 1 of 1
      • Remove the shell the from the back of the camera.
      Ask FixBot
    1. Samsung ST150F Rear Panel Control Board Replacement, Rear Panel Control Board: step 5, image 1 of 1
      • Remove the Phillips head screw from the rear panel control board to reveal the LCD's connection to the motherboard.
      Ask FixBot
    2. Samsung ST150F Rear Panel Control Board Replacement: step 6, image 1 of 3 Samsung ST150F Rear Panel Control Board Replacement: step 6, image 2 of 3 Samsung ST150F Rear Panel Control Board Replacement: step 6, image 3 of 3
      • Remove the Phillips head screws from the metal back plate.
      Ask FixBot
    3. Samsung ST150F Rear Panel Control Board Replacement: step 7, image 1 of 1
      • Use the spudger to life the tab on the side of the metal plate.
      Ask FixBot
    4. Samsung ST150F Rear Panel Control Board Replacement: step 8, image 1 of 2 Samsung ST150F Rear Panel Control Board Replacement: step 8, image 2 of 2
      • Pull gently on the control panel to remove it from the motherboard.
      Ask FixBot
Matthew Eaton
107 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 24
All Time: 1,097
