Samsung SPH-M360 Motherboard Replacement
    1. Samsung SPH-M360 Motherboard Replacement, Remove the back battery panel from the phone.: step 1, image 1 of 2 Samsung SPH-M360 Motherboard Replacement, Remove the back battery panel from the phone.: step 1, image 2 of 2
      • Detach the battery cover by sliding the cover down toward the bottom of the phone.
      • Slide back cover in direction of arrow.
      • Lift up on the battery cover to complete cover removal.
      Ask FixBot
    2. Samsung SPH-M360 Motherboard Replacement, Remove the battery.: step 2, image 1 of 2 Samsung SPH-M360 Motherboard Replacement, Remove the battery.: step 2, image 2 of 2
      • Remove battery by lifting up in the corner of the battery.
      • Use the semi-circle provided in order to gain access to the battery.
      • Battery will come out at an angle. This does not require force.
      Ask FixBot
    3. Samsung SPH-M360 Motherboard Replacement, Unscrew the case: step 3, image 1 of 1
      • Use a phillips head (PH) #00 screwdriver to remove four screws connecting the two halves of the case.
      • Note: keep the screws in a safe location, where they will not be lost until needed for reassembly.
      Ask FixBot
    4. Samsung SPH-M360 Motherboard Replacement, Remove the back half of the case.: step 4, image 1 of 3 Samsung SPH-M360 Motherboard Replacement, Remove the back half of the case.: step 4, image 2 of 3 Samsung SPH-M360 Motherboard Replacement, Remove the back half of the case.: step 4, image 3 of 3
      • Using your plastic opening tool, pry under the back case starting with the top as marked by red circle.
      • There is a small clip at the top of the phone that must be released in order to remove the back case.
      • The volume button and camera button are held in by the back case. Volume button pictured. Camera button opposite.
      • REASSEMBLY ONLY: Replace volume and camera buttons in place. Then, insert the top of the back case FIRST and squeeze together clips as you work toward the bottom of the phone.
      Ask FixBot
    1. Samsung SPH-M360 Motherboard Replacement, Lift the ribbon at the top right of the logic board.: step 5, image 1 of 1
      • Locate the ribbon at the top right corner of the logic board.
      • Use the opening tool to gently lift the ribbon away. It should lift easily.
      • During reassembly, align the gold contacts and black plastic ends, then press lightly until it clicks into place.
      Ask FixBot
    2. Samsung SPH-M360 Motherboard Replacement, Remove the logic board: step 6, image 1 of 3 Samsung SPH-M360 Motherboard Replacement, Remove the logic board: step 6, image 2 of 3 Samsung SPH-M360 Motherboard Replacement, Remove the logic board: step 6, image 3 of 3
      • Insert the plastic opening tool beneath the logic board.
      • While stabilizing the phone, gently lift the board away from the casing. Please do NOT force it! If it resists, apply even pressure in multiple locations.
      • For reassembly, press lightly in 2–4 areas until the board clicks securely into place.
      Ask FixBot
    3. Samsung SPH-M360 Motherboard Replacement, Place the logic board in a safe place: step 7, image 1 of 1
      • If you plan to reuse the logic board, store it in a clean, static-free environment to avoid dust and debris contamination.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Lauryn Bone
97 Reputation
1 Guide authored
Plato Member of Plato
Community
5 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 22
All Time: 663
