Samsung SPH-M360 Logic Board Replacement
  1. Samsung SPH-M360 Logic Board Replacement, Battery: step 1, image 1 of 3 Samsung SPH-M360 Logic Board Replacement, Battery: step 1, image 2 of 3 Samsung SPH-M360 Logic Board Replacement, Battery: step 1, image 3 of 3
    • Locate the arrow on the panel of the rear side of the phone.
    • Use one or two fingers to apply light pressure downwards on the rear panel and push or pull in the direction of the arrow.
    Ask FixBot
  2. Samsung SPH-M360 Logic Board Replacement: step 2, image 1 of 3 Samsung SPH-M360 Logic Board Replacement: step 2, image 2 of 3 Samsung SPH-M360 Logic Board Replacement: step 2, image 3 of 3
    • Place finger inside the small semi-spherical slot near the top of the battery.
    • Lightly pull the battery away from the phone. This should not require much effort.
    Ask FixBot
  3. Samsung SPH-M360 Logic Board Replacement, Casing: step 3, image 1 of 1
    • Remove the four screws on the corners of the casing.
    • The volume and camera buttons may fall out
    Ask FixBot
  4. Samsung SPH-M360 Logic Board Replacement: step 4, image 1 of 2 Samsung SPH-M360 Logic Board Replacement: step 4, image 2 of 2
    • Starting near the top of the casing, use the plastic opening tool to gently pry the casing open.
    • The case should require some effort to pry open, but do not use excessive force for risk of breaking the rear panel.
    • Slowly work the plastic opening tool around the edge of the casing, gently prying it around at all sides.
    Ask FixBot
  5. Samsung SPH-M360 Logic Board Replacement: step 5, image 1 of 2 Samsung SPH-M360 Logic Board Replacement: step 5, image 2 of 2
    • Once the casing has been fully pried off of the phone, it should be easily removed by hand.
    • The buttons for the camera and volume may fall out while removing the casing. Be careful not to lose the small pieces.
    Ask FixBot
  6. Samsung SPH-M360 Logic Board Replacement, Logic Board: step 6, image 1 of 1
    • Use the plastic opening tool to gently detach the golden strip from the logic board.
    • The strip should detach easily with little force required.
    Ask FixBot
  7. Samsung SPH-M360 Logic Board Replacement: step 7, image 1 of 1
    • Use the plastic opening tool to pry the logic board out of the phone case from the bottom area of the phone.
    Ask FixBot
  8. Samsung SPH-M360 Logic Board Replacement: step 8, image 1 of 2 Samsung SPH-M360 Logic Board Replacement: step 8, image 2 of 2
    • Flip the logic board over and locate the three screws along the edges.
    • Carefully unscrew the three screws to remove the panel covering the logic board.
    • Be careful with the screws after unscrewing them because they are small and easy to lose.
    Ask FixBot
  9. Samsung SPH-M360 Logic Board Replacement: step 9, image 1 of 2 Samsung SPH-M360 Logic Board Replacement: step 9, image 2 of 2
    • Flip the logic board back over and use the plastic opening tool to remove the metal cover on the logic board.
    • This will not require much force, so be gentle.
    Ask FixBot
Ashraf Nasser
126 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 33
All Time: 559
