Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓Is your display screen cracked or not operating correctly? Replace it by following these steps.
Tools
Once the battery pack is removed from the phone, remove the five indicated screws with a size #00 Philips screwdriver.
Bend back the antenna to access the indicated left middle screw in order to unscrew it.
To start, remove the two highlighted sticky covers using the blue prying tool or your finger. Prying off the stickers allows access to the screws underneath.
Slide the tool or your fingernail under the stickers and they should come off with relative ease.
Next, insert a plastic opening tool into the crack that runs along the side of the phone display under the screws. Doing so will start lift the display screen.
Once you have the display cover open, use your fingers to pry the whole outside cover off. Only do so to the top half of the phone.
Set the outside display cover aside. The two separate parts should look like the third picture.
Carefully wedge a plastic opening tool between the hinge on the body of the phone.
Slowly pry the hinge from the body, as shown in the second picture. Set the phone down after when finished with this step.
Next, slide the connector cable out of the slot on the back side of the phone and the screen will be disconnected from the key pad body.
