Up to 20% off select tools
Samsung SPH-A500 Keypad Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
85
All Time:
2,444
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
Repair guide on how to replace the keypad in a Samsung SPH-A500.
    1. Samsung SPH-A500 Keypad Replacement, Keypad: step 1, image 1 of 1
      • Turn phone over
      • Push the gray tab above the battery forward to remove the battery.
      Ask FixBot
    2. Samsung SPH-A500 Keypad Replacement: step 2, image 1 of 1
      • Remove the battery from the phone, which will reveal four screws at the corners of the phone.
      Ask FixBot
    3. Samsung SPH-A500 Keypad Replacement: step 3, image 1 of 1
      • Remove all four screws using a small Philips screwdriver.
      • Note: The screws do not need to be completely removed from the case, as long as they are unscrewed.
      Ask FixBot
    4. Samsung SPH-A500 Keypad Replacement: step 4, image 1 of 1
      • Remove back cover by carefully prying it open.
      • Note: Some force may be required.
      Ask FixBot
    5. Samsung SPH-A500 Keypad Replacement: step 5, image 1 of 1
      • Pull the side tabs outward while simultaneously lifting up the circuit board.
      Ask FixBot
    6. Samsung SPH-A500 Keypad Replacement: step 6, image 1 of 1
      • Lift circuit board from the bottom of the phone.
      • WARNING: DO NOT completely remove circuit board from the phone, since it is still attached at the top of the phone.
      Ask FixBot
    7. Samsung SPH-A500 Keypad Replacement: step 7, image 1 of 1
      • Flip the circuit board around the top of the phone.
      • Lift the rubber keypad off.
      Ask FixBot
    8. Samsung SPH-A500 Keypad Replacement: step 8, image 1 of 1
      • Replace the keypad.
      Ask FixBot
Author
with
Nick Dominikovic
139 Reputation
4 Guides authored
Cal Poly, Team 18-100, Johann Spring 2010 Member of Cal Poly, Team 18-100, Johann Spring 2010
CPSU-JOHANN-S10S18G100
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 85
All Time: 2,444
