Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓This is an easy DIY guide on how to replace the Samsung SPEX SCH-R210 keypad. You will need 2 different screwdrivers for this guide. This requires removing the back cover, the battery, and the motherboard. The keypad will pop out easily after the motherboard is removed.
Lay the phone on its front side so the back is visible.
Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
Slide the cover down from the phone to remove it. Set the cover aside.
Remove the four 4.8 mm screws from the midframe using a Phillips #00 screwdriver.
