Samsung SGH-E317 SIM Card Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
79
All Time:
2,582
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
In this guide, we will be replacing the SIM card in the Samsung SGH-E317. SIM stands for Subscriber Identification Module. Basically, it tells the phone and the service provider the Identity of the phone. It gives basic information such as the phone number that is being used and the mobile provider that is servicing the phone. By changing the SIM card, you will be able to operate the phone under a new phone number or even under an entirely new mobile service provider! Follow the steps below, and you will have your new SIM card installed in no time!
Please keep in mind, that once a SIM card has been replaced, you may need to restart your phone in order to make it operate using the new SIM! Simply turn the phone off for a few minutes, and turn it back on again and the new SIM should be active!
Tools
    1. Samsung SGH-E317 SIM Card Replacement, Battery: step 1, image 1 of 1
      • Remove the back panel by pressing up on switch, located at the top on the back of the phone.
      • You may want to use a plastic opening tool to help pry the back panel off.
      Ask FixBot
    1. Samsung SGH-E317 SIM Card Replacement, SIM Card: step 2, image 1 of 1
      • Gently slide the SIM card into the slot, oriented as in the picture.
      Ask FixBot
2 other people completed this guide.
Laura MacCarley
276 Reputation
2 Guides authored
Cal Poly, Team 11-23, Maness Winter 2011 Member of Cal Poly, Team 11-23, Maness Winter 2011
CPSU-MANESS-W11S11G23
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 79
All Time: 2,582
