Samsung SGH-E317 Camera Replacement
    1. Samsung SGH-E317 Camera Replacement, Battery: step 1, image 1 of 1
      • Remove the back panel by pressing up on switch, located at the top on the back of the phone.
      • You may want to use a plastic opening tool to help pry the back panel off.
      Ask FixBot
    1. Samsung SGH-E317 Camera Replacement, Motherboard: step 2, image 1 of 1
      • Unscrew the four 4.5mm screws located on the back plate.
      Ask FixBot
    2. Samsung SGH-E317 Camera Replacement: step 3, image 1 of 1
      • Remove the rubber screw cover using your fingernail.
      Ask FixBot
    3. Samsung SGH-E317 Camera Replacement: step 4, image 1 of 1
      • Unscrew the 4.5mm screw located underneath the rubber cover.
      Ask FixBot
    4. Samsung SGH-E317 Camera Replacement: step 5, image 1 of 1
      • Wedge the end of a plastic opening tool into the crack between the back panel and the phone.
      • The panel should come off without much effort.
      Ask FixBot
    5. Samsung SGH-E317 Camera Replacement: step 6, image 1 of 1
      • With the back panel removed, the motherboard should be fully exposed.
      Ask FixBot
    6. Samsung SGH-E317 Camera Replacement: step 7, image 1 of 2 Samsung SGH-E317 Camera Replacement: step 7, image 2 of 2
      • Remove the camera and volume buttons and place them in a safe spot until reassembly.
      Ask FixBot
    7. Samsung SGH-E317 Camera Replacement: step 8, image 1 of 2 Samsung SGH-E317 Camera Replacement: step 8, image 2 of 2
      • Using a plastic opening tool, unplug the ribbon cable connecting the front LCDs to the motherboard.
      Ask FixBot
    8. Samsung SGH-E317 Camera Replacement: step 9, image 1 of 2 Samsung SGH-E317 Camera Replacement: step 9, image 2 of 2
      • Detach the motherboard by grabbing the edges of it and lifting it straight out of the phone.
      Ask FixBot
    1. Samsung SGH-E317 Camera Replacement, Camera: step 10, image 1 of 2 Samsung SGH-E317 Camera Replacement, Camera: step 10, image 2 of 2
      • Use a spudger to remove the plastic screw coverings at the base of the LCD screen.
      Ask FixBot
    2. Samsung SGH-E317 Camera Replacement: step 11, image 1 of 1
      Tool used on this step:
      Buy
      • Use the screwdriver to remove the two 4.5mm screws located underneath the plastic coverings.
      • You may want to use tweezers to remove the loosened screws.
      Ask FixBot
    3. Samsung SGH-E317 Camera Replacement: step 12, image 1 of 1
      • Wedge the plastic opening tool under the crevice on the inner surface of the phone screen.
      • Gently pry the top panel off around the entire frame.
      Ask FixBot
    4. Samsung SGH-E317 Camera Replacement: step 13, image 1 of 2 Samsung SGH-E317 Camera Replacement: step 13, image 2 of 2
      • Make sure that the top panel is completely separated from the LCD display around the entire perimeter.
      Ask FixBot
    5. Samsung SGH-E317 Camera Replacement: step 14, image 1 of 1
      • Take the top panel off of the phone.
      Ask FixBot
    6. Samsung SGH-E317 Camera Replacement: step 15, image 1 of 2 Samsung SGH-E317 Camera Replacement: step 15, image 2 of 2
      • Use the wedge to detach the connecting wire panel from the LCD display system.
      • Be gentle when detatching this wire to prevent damaging surrounding components.
      Ask FixBot
    7. Samsung SGH-E317 Camera Replacement: step 16, image 1 of 2 Samsung SGH-E317 Camera Replacement: step 16, image 2 of 2
      • Use the tweezers to remove the camera from the cellphone casing.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order.Take your e-waste to an R2 or e-Stewards certified recycler.
Michael Strange
101 Reputation
1 Guide authored
Cal Poly, Team 11-23, Maness Winter 2011 Member of Cal Poly, Team 11-23, Maness Winter 2011
CPSU-MANESS-W11S11G23
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 28
All Time: 1,936
