Up to 20% off select tools
Samsung SGH-A737 Screen Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
83
All Time:
787
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
      • Remove battery from the back of the device.
      Ask FixBot
      • Use a Phillips head screw driver to unscrew six screws on back on the device.
      Ask FixBot
      • Using the same screw driver, slide up the screen and remove two more screws beside the camera.
      Ask FixBot
      • Remove side buttons and pop out circuit board, this will expose two more screws. Remove these and keep them separate from the rest.
      Ask FixBot
      • Remove the Samsung sticker to expose two metal tabs.
      Ask FixBot
    1. Samsung SGH-A737 Screen  Replacement: step 6, image 1 of 1
      • Peel off the black strip to expose two screws. Remove these.
      Ask FixBot
    2. Samsung SGH-A737 Screen  Replacement: step 7, image 1 of 1
      • Use a Phillips head screwdriver to remove the four screws on the back of the screen.
      Ask FixBot
    3. Samsung SGH-A737 Screen  Replacement: step 8, image 1 of 1
      • Once you have exposed the circuit board, peel off the green tape at the bottom. This will allow the removal of the screen.
      Ask FixBot
      • Before removing the screen, disconnect the orange tape at the top of the circuit board. You can do this by opening up the small lock.
      • With the lock opened, the circuit board will automatically detach when you pull it out in step 11.
      Ask FixBot
      • Use a flathead screwdriver to reach under the circuit board and pry it up. You should hear a tearing sound; this is the glue separating from the screen.
      Ask FixBot
      • Once you have pried it up, the screen should come out easily. The camera and its microphone are attached at the top(outlined in red).
      • With the screen removed, you can then put the new one in. You must attach the orange strip to the new circuit board to properly install it.
      Ask FixBot
Author
with
Tommy
101 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 83
All Time: 787
