Samsung SGH-A237 Camera Replacement
    1. Samsung SGH-A237 Camera Replacement, Camera: step 1, image 1 of 1
      • Place the phone on a flat surface with the camera facing upwards.
      • Have a designated space to keep track of each small part.
      Ask FixBot
    2. Samsung SGH-A237 Camera Replacement: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Open the phone.
      • Remove the two rubber soft screw covers below the viewing screen using a pair of tweezers.
      Ask FixBot
    3. Samsung SGH-A237 Camera Replacement: step 3, image 1 of 1
      • Loosen the screws under the soft screw covers using a Phillips #00 screwdriver.
      Ask FixBot
    4. Samsung SGH-A237 Camera Replacement: step 4, image 1 of 3 Samsung SGH-A237 Camera Replacement: step 4, image 2 of 3 Samsung SGH-A237 Camera Replacement: step 4, image 3 of 3
      • Failure to utilize the specified tool may cause damage to the device.
      • Locate the black cover plate on the back side of the viewing screen. It will show the AT&T and Samsung logos.
      • Look on the right side of the phone for the crease in between the black back cover and the front silver cover of the viewing screen.
      • Pry the cover plate off using a plastic opening tool.
      Ask FixBot
    5. Samsung SGH-A237 Camera Replacement: step 5, image 1 of 2 Samsung SGH-A237 Camera Replacement: step 5, image 2 of 2
      • Identify the metal bracket that covers the internal body.
      • Identify the metal tabs surrounding the metal bracket mentioned in the previous step.
      • Remove the metal bracket using a small pick or a Phillips #00 screwdriver.
      • Close the phone.
      Ask FixBot
    6. Samsung SGH-A237 Camera Replacement: step 6, image 1 of 1
      • Find the camera on the upper part of the phone. It will be displayed as a small black circle.
      • Follow the copper ribbon connected to the camera downward to the black connection port.
      Ask FixBot
    7. Samsung SGH-A237 Camera Replacement: step 7, image 1 of 2 Samsung SGH-A237 Camera Replacement: step 7, image 2 of 2
      • Failure to utilize the specified tool in the proper way may cause damage to the device.
      • Pry up the black connector using a pick. This should lock the black connector into an upward position, which will release the copper ribbon connected to the phone's camera.
      Ask FixBot
    8. Samsung SGH-A237 Camera Replacement: step 8, image 1 of 2 Samsung SGH-A237 Camera Replacement: step 8, image 2 of 2
      • Gently grasp the copper ribbon attached to the camera using a pair of tweezers.
      • Gently pull copper ribbon towards the camera. This should pull the copper ribbon out completely.
      Ask FixBot
    9. Samsung SGH-A237 Camera Replacement: step 9, image 1 of 1
      • Remove the camera.
      Ask FixBot
Jonathon
10 Reputation
1 Guide authored
Ohio State, Team 1-4, Mccook Fall 2014 Member of Ohio State, Team 1-4, Mccook Fall 2014
OSU-MCCOOK-F14S1G4
3 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 22
All Time: 795
