Samsung SGH-A137 Motherboard Replacement
    1. Samsung SGH-A137 Motherboard Replacement, Battery: step 1, image 1 of 1
      • Use your thumbs to pull down on the back cover to remove it and expose the battery.
      Ask FixBot
    2. Samsung SGH-A137 Motherboard Replacement: step 2, image 1 of 1
      • Locate the indent in the case below the battery. (see red square)
      • Place your finger at the indent and pull up on the battery to remove it.
      Ask FixBot
    1. Samsung SGH-A137 Motherboard Replacement, Motherboard: step 3, image 1 of 3 Samsung SGH-A137 Motherboard Replacement, Motherboard: step 3, image 2 of 3 Samsung SGH-A137 Motherboard Replacement, Motherboard: step 3, image 3 of 3
      • Locate the 4 screw holes and remove the 0.4 mm Phillips head screws using a #000 Phillips head screwdriver. (See red circles)
      Ask FixBot
    2. Samsung SGH-A137 Motherboard Replacement: step 4, image 1 of 1
      • Using a plastic opening tool, gently pry open the back of the phone at the seam.
      • Carefully work the tool all the way around the opening while prying up to avoid breaking the plastic retaining clips.
      Ask FixBot
    3. Samsung SGH-A137 Motherboard Replacement: step 5, image 1 of 2 Samsung SGH-A137 Motherboard Replacement: step 5, image 2 of 2
      • Smaller press-fit connectors may require a simple flick with a plastic opening tool or spudger.
      • Place the flat edge of a spudger under the edge of the press-fit connector and , gently pry the connector straight up from its socket. (Highlighted by the red square)
      Ask FixBot
    4. Samsung SGH-A137 Motherboard Replacement: step 6, image 1 of 1
      • Using a plastic opening tool, gently pry up the motherboard.
      • You might need to pry from several different locations to get the motherboard loose enough to remove.
      Ask FixBot
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 45
All Time: 1,017
