Samsung SGH A707 Camera Replacement
    1. Samsung SGH A707 Camera Replacement, Battery: step 1, image 1 of 1
      • Press on the markings on the cover and pull it down to reveal the battery.
      Ask FixBot
    2. Samsung SGH A707 Camera Replacement: step 2, image 1 of 1
      • Use your fingers to pull the battery out of its position. You may also flip the phone and the battery will fall out.
      Ask FixBot
    3. Samsung SGH A707 Camera Replacement: step 3, image 1 of 1
      • Here is the phone without the battery.
      Ask FixBot
    1. Samsung SGH A707 Camera Replacement, Motherboard: step 4, image 1 of 2 Samsung SGH A707 Camera Replacement, Motherboard: step 4, image 2 of 2
      • Unscrew the six screws on the back of the phone using the Phillips #0 screw driver.
      Ask FixBot
    2. Samsung SGH A707 Camera Replacement: step 5, image 1 of 1
      • Use the prying tool the pry off the phone's plastic frame.
      Ask FixBot
    3. Samsung SGH A707 Camera Replacement: step 6, image 1 of 3 Samsung SGH A707 Camera Replacement: step 6, image 2 of 3 Samsung SGH A707 Camera Replacement: step 6, image 3 of 3
      • Use the prying tool to disconnect the rectangular connector.
      Ask FixBot
    4. Samsung SGH A707 Camera Replacement: step 7, image 1 of 1
      • Use the prying tool to disconnect the small connector.
      Ask FixBot
    5. Samsung SGH A707 Camera Replacement: step 8, image 1 of 1
      • Gently pull off the circuit board.
      Ask FixBot
    6. Samsung SGH A707 Camera Replacement: step 9, image 1 of 1
      • Here is the phone without the logic board.
      Ask FixBot
    1. Samsung SGH A707 Camera Replacement, Keypad: step 10, image 1 of 1
      • Hold the phone and gently separate the circuit board that holds the dome switches and the front face of the phone, revealing the rubber keyboard.
      Ask FixBot
    2. Samsung SGH A707 Camera Replacement: step 11, image 1 of 1
      • Here is the phone without the dome switch circuit board.
      Ask FixBot
    3. Samsung SGH A707 Camera Replacement: step 12, image 1 of 2 Samsung SGH A707 Camera Replacement: step 12, image 2 of 2
      • Here is the phone and the rubber keyboard.
      Ask FixBot
    4. Samsung SGH A707 Camera Replacement: step 13, image 1 of 1
      • Here is the rubber keyboard and the dome switch circuit board. A quick inspection of these elements can reveal keypad malfunctions. Look for dirt or debris that do not belong there.
      Ask FixBot
    1. Samsung SGH A707 Camera Replacement, Front Pane: step 14, image 1 of 2 Samsung SGH A707 Camera Replacement, Front Pane: step 14, image 2 of 2
      • Use the Phillips #0 screw driver to remove the two screws.
      • Place the screws in a safe place.
      • Use the prying tool to gently pry the screen off, by slowly moving the prying tool around the entire edge of the screen (roughly highlighted with a red rectangle). You must be very gentle, otherwise the screen will crack.
      Ask FixBot
    2. Samsung SGH A707 Camera Replacement: step 15, image 1 of 1
      • Now we have access to the camera.
      • We also have access to the speakers.
      • Disconnect the flat cable to separate the two pieces.
      Ask FixBot
    3. Samsung SGH A707 Camera Replacement: step 16, image 1 of 1
      • Samsung SGH A707
      Ask FixBot
    1. Samsung SGH A707 Camera Replacement, Camera: step 17, image 1 of 1
      • Separate the two flaps to make handling easier.
      • Use a screw driver to press a latch in along the axis of the hinge and simultaneously pull the pieces apart.
      • Gently pull the flat cable through the hinge.
      Ask FixBot
    2. Samsung SGH A707 Camera Replacement: step 18, image 1 of 1
      • Disconnect the flat cable for the camera from the circuit board.
      • Use the prying tool to remove the camera. It is secured in place by glue, so some force is needed.
      • Be careful not to slip the tool onto your hand as you apply force.
      Ask FixBot
    3. Samsung SGH A707 Camera Replacement: step 19, image 1 of 1
      • Here is the camera removed from the rest of the phone.
      Ask FixBot
yfm
25 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 19
All Time: 870
