Up to 20% off select tools
Samsung SCV-VLUUST50 Shutter Button Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
64
All Time:
776
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Is your shutter button not working correctly? Here is a replacement guide for the Samsung SCV-VLUUST50 shutter button. You will need a driver kit and a spudger to complete this replacement.
    1. Samsung SCV-VLUUST50 Shutter Button Replacement, Cover: step 1, image 1 of 3 Samsung SCV-VLUUST50 Shutter Button Replacement, Cover: step 1, image 2 of 3 Samsung SCV-VLUUST50 Shutter Button Replacement, Cover: step 1, image 3 of 3
      • Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
      • Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
      Ask FixBot
    2. Samsung SCV-VLUUST50 Shutter Button Replacement: step 2, image 1 of 3 Samsung SCV-VLUUST50 Shutter Button Replacement: step 2, image 2 of 3 Samsung SCV-VLUUST50 Shutter Button Replacement: step 2, image 3 of 3
      • Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
      • Remove the corner panel by applying pressure away from the shutter button.
      • The memory card cover will come off with the corner panel.
      • Remove the top panel by applying gentle pressure away from the shutter button.
      Ask FixBot
    3. Samsung SCV-VLUUST50 Shutter Button Replacement: step 3, image 1 of 1
      • Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
      Ask FixBot
    4. Samsung SCV-VLUUST50 Shutter Button Replacement: step 4, image 1 of 2 Samsung SCV-VLUUST50 Shutter Button Replacement: step 4, image 2 of 2
      • Remove the front and back covers by pulling them straight apart.
      Ask FixBot
    1. Samsung SCV-VLUUST50 Shutter Button Replacement, Shutter Button: step 5, image 1 of 3 Samsung SCV-VLUUST50 Shutter Button Replacement, Shutter Button: step 5, image 2 of 3 Samsung SCV-VLUUST50 Shutter Button Replacement, Shutter Button: step 5, image 3 of 3
      • Remove the screw below the shutter button with a Phillips #000 screw driver.
      • Once the screw is removed the shutter button should easily come off, and you can replace it with the new button.
      Ask FixBot
Author
with
Jaeda Ransom
123 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 64
All Time: 776
