Samsung SCV-VLUUST50 Flash Capacitor Replacement
    1. Samsung SCV-VLUUST50 Flash Capacitor Replacement, Cover: step 1, image 1 of 3 Samsung SCV-VLUUST50 Flash Capacitor Replacement, Cover: step 1, image 2 of 3 Samsung SCV-VLUUST50 Flash Capacitor Replacement, Cover: step 1, image 3 of 3
      • Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
      • Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
      Ask FixBot
    2. Samsung SCV-VLUUST50 Flash Capacitor Replacement: step 2, image 1 of 3 Samsung SCV-VLUUST50 Flash Capacitor Replacement: step 2, image 2 of 3 Samsung SCV-VLUUST50 Flash Capacitor Replacement: step 2, image 3 of 3
      • Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
      • Remove the corner panel by applying pressure away from the shutter button.
      • The memory card cover will come off with the corner panel.
      • Remove the top panel by applying gentle pressure away from the shutter button.
      Ask FixBot
    3. Samsung SCV-VLUUST50 Flash Capacitor Replacement: step 3, image 1 of 1
      • Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
      Ask FixBot
    4. Samsung SCV-VLUUST50 Flash Capacitor Replacement: step 4, image 1 of 2 Samsung SCV-VLUUST50 Flash Capacitor Replacement: step 4, image 2 of 2
      • Remove the front and back covers by pulling them straight apart.
      Ask FixBot
    1. Samsung SCV-VLUUST50 Flash Capacitor Replacement, Flash Capacitor: step 5, image 1 of 2 Samsung SCV-VLUUST50 Flash Capacitor Replacement, Flash Capacitor: step 5, image 2 of 2
      • Remove the screw securing the shutter button.
      • Lift the shutter button to remove it.
      Ask FixBot
    2. Samsung SCV-VLUUST50 Flash Capacitor Replacement: step 6, image 1 of 2 Samsung SCV-VLUUST50 Flash Capacitor Replacement: step 6, image 2 of 2
      • Remove the 3 visible screws with a Phillips #000 Driver
      • Move the circuitry and wires out of the way to expose another screw, and remove it with the same driver.
      Ask FixBot
    3. Samsung SCV-VLUUST50 Flash Capacitor Replacement: step 7, image 1 of 3 Samsung SCV-VLUUST50 Flash Capacitor Replacement: step 7, image 2 of 3 Samsung SCV-VLUUST50 Flash Capacitor Replacement: step 7, image 3 of 3
      • Pull the flash capacitor out of its compartment to expose the wires connected to it.
      • Cut the connecting wires with wire cutters.
      • Solder the wires to the new power source with a soldering iron and electrical solder.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 7
All Time: 497
