Samsung SCH-U340 Top Casing Replacement
    1. Samsung SCH-U340 Top Casing Replacement, Battery: step 1, image 1 of 1
      • Turn the cell phone so that the back side is facing you.
      • Press the upper indent and slide the back cover down.
      Ask FixBot
    2. Samsung SCH-U340 Top Casing Replacement: step 2, image 1 of 1
      • Pull the battery up from indent at the bottom and slide it out.
      Ask FixBot
    3. Samsung SCH-U340 Top Casing Replacement: step 3, image 1 of 1
      • Set the battery aside.
      Ask FixBot
    1. Samsung SCH-U340 Top Casing Replacement, Top Casing: step 4, image 1 of 1
      • The outer casing consists of two separate parts on the upper and lower halves of the device. The upper outer casing is held on through a combination of screws and tabs.
      • First, remove the plastic plugs covering the screws with a spudger.
      Ask FixBot
    2. Samsung SCH-U340 Top Casing Replacement: step 5, image 1 of 1
      • Underneath the plugs are two small screws that can be removed with a small Phillips screwdriver.
      • The screws will need to be pried out after unscrewing them due to their size.
      • Take care not to lose the screws as they are small and have a tendency to roll.
      Ask FixBot
    3. Samsung SCH-U340 Top Casing Replacement: step 6, image 1 of 1
      • The outer cover is now secured with seven tabs: one large tab (marked in red) and seven smaller tabs (marked in orange).
      • To begin removing the outer cover, start by prying the large tab up with a flat object.
      • See next slide for details for smaller tabs.
      Ask FixBot
    4. Samsung SCH-U340 Top Casing Replacement: step 7, image 1 of 1
      • Continue to pry each smaller tab up, taking care not to break the tabs.
      • If disaster strikes and a tab is broken, the outer casing can still be put back on assuming the majority of the tabs are still intact.
      Ask FixBot
    5. Samsung SCH-U340 Top Casing Replacement: step 8, image 1 of 1
      • After the last tab is removed, tug gently on the outer casing to remove it.
      • Don't pull too hard, or you may damage the wires connected to the speaker.
      Ask FixBot
Anish Sambamurthy
31 Reputation
2 Guides authored
Cal Poly, Team 3-21, Maness Winter 2010 Member of Cal Poly, Team 3-21, Maness Winter 2010
CPSU-MANESS-W10S3G21
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 33
All Time: 3,186
