Samsung SCH-U340 Internal Antenna Replacement
    1. Samsung SCH-U340 Internal Antenna Replacement, Battery: step 1, image 1 of 1
      • Turn the cell phone so that the back side is facing you.
      • Press the upper indent and slide the back cover down.
      Ask FixBot
    2. Samsung SCH-U340 Internal Antenna Replacement: step 2, image 1 of 1
      • Pull the battery up from indent at the bottom and slide it out.
      Ask FixBot
    3. Samsung SCH-U340 Internal Antenna Replacement: step 3, image 1 of 1
      • Set the battery aside.
      Ask FixBot
    1. Samsung SCH-U340 Internal Antenna Replacement, Lower Casing: step 4, image 1 of 1
      • The lower casing is held on by four screws in the corner of the battery enclosure. Remove these screws.
      Ask FixBot
    2. Samsung SCH-U340 Internal Antenna Replacement: step 5, image 1 of 2 Samsung SCH-U340 Internal Antenna Replacement: step 5, image 2 of 2
      • Use a spudger to pry the back assembly off of the device.
      Ask FixBot
    1. Samsung SCH-U340 Internal Antenna Replacement, Internal Antenna: step 6, image 1 of 1
      • On the bottom casing, there should be a single metal screw holding the antennae in. Remove this screw.
      Ask FixBot
    2. Samsung SCH-U340 Internal Antenna Replacement: step 7, image 1 of 2 Samsung SCH-U340 Internal Antenna Replacement: step 7, image 2 of 2
      • Pry the antennae off by inserting a flat object such as a spudgel into the slot marked in yellow and pushing upwards.
      Ask FixBot
David Gomez
1 Reputation
1 Guide authored
Cal Poly, Team 3-21, Maness Winter 2010 Member of Cal Poly, Team 3-21, Maness Winter 2010
CPSU-MANESS-W10S3G21
4 Members
55 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 31
All Time: 3,514
