Samsung SCH-A670 Logic Board Replacement
  1. Samsung SCH-A670 Logic Board Replacement, Battery Cover: step 1, image 1 of 1
    • Slide the latch on the back of the phone up.
    Ask FixBot
  2. Samsung SCH-A670 Logic Board Replacement, Battery: step 2, image 1 of 1
    • Remove the battery.
    Ask FixBot
  3. Samsung SCH-A670 Logic Board Replacement, Logic Board: step 3, image 1 of 1
    • After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
    Ask FixBot
  4. Samsung SCH-A670 Logic Board Replacement: step 4, image 1 of 1
    • Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
    Ask FixBot
  5. Samsung SCH-A670 Logic Board Replacement: step 5, image 1 of 1
    • With a #0 Phillips screwdriver remove the screw which you just uncovered.
    Ask FixBot
  6. Samsung SCH-A670 Logic Board Replacement: step 6, image 1 of 2 Samsung SCH-A670 Logic Board Replacement: step 6, image 2 of 2
    • Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open.
    • Then disconnect the small power connector near the top of the phone.
    Ask FixBot
  7. Samsung SCH-A670 Logic Board Replacement: step 7, image 1 of 1
    • Gently pry up the ribbon-type connector with the spudger.
    Ask FixBot
  8. Samsung SCH-A670 Logic Board Replacement: step 8, image 1 of 1
    • Carefully pry the logic board from the case with the spudger.
    Ask FixBot
Finish Line
Nathan Brink
19 Reputation
7 Guides authored
Cal Poly, Team 34-59, Forte Spring 2010 Member of Cal Poly, Team 34-59, Forte Spring 2010
CPSU-FORTE-S10S34G59
4 Members
28 Guides authored
1 Guide Comment
Perfect instructions to remove the back of the case. Thanks
John Berg - Reply Share
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 36
All Time: 3,087
