Samsung SCH-A670 Keypad Replacement
    1. Samsung SCH-A670 Keypad Replacement, Battery Cover: step 1, image 1 of 1
      • Slide the latch on the back of the phone up.
      Ask FixBot
    2. Samsung SCH-A670 Keypad Replacement, Battery: step 2, image 1 of 1
      • Remove the battery.
      Ask FixBot
    1. Samsung SCH-A670 Keypad Replacement, Logic Board: step 3, image 1 of 1
      • After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
      Ask FixBot
    2. Samsung SCH-A670 Keypad Replacement: step 4, image 1 of 1
      • Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
      Ask FixBot
    3. Samsung SCH-A670 Keypad Replacement: step 5, image 1 of 1
      • With a #0 Phillips screwdriver remove the screw which you just uncovered.
      Ask FixBot
    4. Samsung SCH-A670 Keypad Replacement: step 6, image 1 of 2 Samsung SCH-A670 Keypad Replacement: step 6, image 2 of 2
      • Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open.
      • Then disconnect the small power connector near the top of the phone.
      Ask FixBot
    5. Samsung SCH-A670 Keypad Replacement: step 7, image 1 of 1
      • Gently pry up the ribbon-type connector with the spudger.
      Ask FixBot
    6. Samsung SCH-A670 Keypad Replacement: step 8, image 1 of 1
      • Carefully pry the logic board from the case with the spudger.
      Ask FixBot
    1. Samsung SCH-A670 Keypad Replacement, Keypad: step 9, image 1 of 1
      • Once the logic board has been removed, peel the keypad up.
      Ask FixBot
Nathan Brink
19 Reputation
7 Guides authored
Cal Poly, Team 34-59, Forte Spring 2010 Member of Cal Poly, Team 34-59, Forte Spring 2010
CPSU-FORTE-S10S34G59
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 32
All Time: 1,934
