Samsung SCH-8500 Volume Button Replacement
    1. Samsung SCH-8500 Volume Button Replacement, Battery: step 1, image 1 of 3 Samsung SCH-8500 Volume Button Replacement, Battery: step 1, image 2 of 3 Samsung SCH-8500 Volume Button Replacement, Battery: step 1, image 3 of 3
      • To separate the battery from the phone, use your thumb to push in the button as shown.
      • Keep the unlock button pressed as you slide the battery away from the button.
      • Pull the battery away from the phone.
      Ask FixBot
    1. Samsung SCH-8500 Volume Button Replacement, Back Case: step 2, image 1 of 3 Samsung SCH-8500 Volume Button Replacement, Back Case: step 2, image 2 of 3 Samsung SCH-8500 Volume Button Replacement, Back Case: step 2, image 3 of 3
      • Use a T6 Torx screwdriver to remove the highlighted screws.
      • These are the four screws, about 10 mm long, that need to be removed. Be careful with the screws as they are small and easy to misplace.
      • Carefully pry apart the two pieces, laying the back case to the side.
      Ask FixBot
    1. Samsung SCH-8500 Volume Button Replacement, Volume Button: step 3, image 1 of 3 Samsung SCH-8500 Volume Button Replacement, Volume Button: step 3, image 2 of 3 Samsung SCH-8500 Volume Button Replacement, Volume Button: step 3, image 3 of 3
      • With the back case fully removed and out of the way, use your fingers to remove the volume button.
      • Use caution in removal to prevent damaging any circuitry in the phone.
      Ask FixBot
Will Gunter
1 Reputation
4 Guides authored
Clemson, Team 14-6, Benson Fall 2012 Member of Clemson, Team 14-6, Benson Fall 2012
CLEM-BENSON-F12S14G6
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 21
All Time: 526
