Up to 20% off select tools
Samsung S860 LCD Screen Replacement
Views: 10K
View statistics:
Past 24 Hours:
6
Past 7 Days:
29
Past 30 Days:
137
All Time:
10,271
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Missing Steps
Oops! This guide is currently missing one or more important steps.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
You will take the camera apart in order to replace the damaged LCD screen and restore functionality.
    1. Samsung S860 LCD Screen Replacement, LCD Screen: step 1, image 1 of 2 Samsung S860 LCD Screen Replacement, LCD Screen: step 1, image 2 of 2
      • Remove all screws along the edges of the camera, using a #00 Phillips screwdriver.
      Ask FixBot
    2. Samsung S860 LCD Screen Replacement: step 2, image 1 of 1
      • Slide open the battery compartment cover before removing the exterior covers of the camera.
      Ask FixBot
    3. Samsung S860 LCD Screen Replacement: step 3, image 1 of 3 Samsung S860 LCD Screen Replacement: step 3, image 2 of 3 Samsung S860 LCD Screen Replacement: step 3, image 3 of 3
      • Carefully pull the back case (the side showing the LCD screen) away from the front half.
      • There are clips securing the top of the back case. Do not be afraid to use the proper amount of force to remove the back case.
      • Turn the camera around to the front (the lens side). Carefully remove the front case.
      • There are also clips on the lens' side as well, so do not be afraid to use force.
      Ask FixBot
    4. Samsung S860 LCD Screen Replacement: step 4, image 1 of 2 Samsung S860 LCD Screen Replacement: step 4, image 2 of 2
      • Position the camera so the LCD screen is facing you.
      • Remove the LCD screen from the screen plate.
      • Replace the broken LCD screen with the functioning LCD screen.
      Ask FixBot
3 other people completed this guide.
Author
with
Kando Ogunrinola
203 Reputation
3 Guides authored
Cal Poly, Team 33-72, Johann Spring 2010 Member of Cal Poly, Team 33-72, Johann Spring 2010
CPSU-JOHANN-S10S33G72
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 29
Past 30 Days: 137
All Time: 10,271
