Samsung S85 Rubber Door Replacement
    1. Samsung S85 Rubber Door Replacement, Rubber Door: step 1, image 1 of 3 Samsung S85 Rubber Door Replacement, Rubber Door: step 1, image 2 of 3 Samsung S85 Rubber Door Replacement, Rubber Door: step 1, image 3 of 3
      • Remove 4 screws from bottom of camera
      • Remove 2 screws from side of camera
      • Place Screws on magnetic surface or location where they will not roll away
      Ask FixBot
    2. Samsung S85 Rubber Door Replacement: step 2, image 1 of 1
      • Squeeze area noted by blue square and pull outside shell apart from remaining camera.
      Ask FixBot
    3. Samsung S85 Rubber Door Replacement: step 3, image 1 of 2 Samsung S85 Rubber Door Replacement: step 3, image 2 of 2
      • Remove 6 screws identified by red circles
      • Remove 3 screws identified by orange circles
      Ask FixBot
    4. Samsung S85 Rubber Door Replacement: step 4, image 1 of 2 Samsung S85 Rubber Door Replacement: step 4, image 2 of 2
      • Gently remove orange circuit ribbon identified by red square
      • Gently remove narrow orange circuit ribbon identified by blue square
      Ask FixBot
    5. Samsung S85 Rubber Door Replacement: step 5, image 1 of 3 Samsung S85 Rubber Door Replacement: step 5, image 2 of 3 Samsung S85 Rubber Door Replacement: step 5, image 3 of 3
      • Be very cautious when using a soldering iron (they are on average 300 F)
      • Using a soldering iron, remove solder from wire identified by red circle
      • Using a soldering iron, remove solder from black and red wire identified by orange circle
      • Using a soldering iron, remove solder from wire identified by yellow circle
      Ask FixBot
    6. Samsung S85 Rubber Door Replacement: step 6, image 1 of 3 Samsung S85 Rubber Door Replacement: step 6, image 2 of 3 Samsung S85 Rubber Door Replacement: step 6, image 3 of 3
      • Using soldering iron, melt away solder and warm up metal located at top of circuit board as shown in picture
      • Repeat step two to three times until board feels flexible to bend
      • Slowly bend circuit board upwards (towards power button) until at 90 degree angle with remaining part of camera.
      Ask FixBot
    7. Samsung S85 Rubber Door Replacement: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • Remove black rubber door located on side of camera closest to lens using tweezers.
      • Be careful not to bend or tear the rubber when pulling out with tweezers as it may become difficult to put back in
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 31
All Time: 758
