Up to 20% off select tools
Samsung S760 LCD Screen Replacement Guide
Views: 1.9K
View statistics:
Past 24 Hours:
5
Past 7 Days:
27
Past 30 Days:
110
All Time:
1,880
Comments: 1
1 comment on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The LCD screen can be cracked or water damaged
    1. Samsung S760 LCD Screen Replacement Guide, Battery: step 1, image 1 of 3 Samsung S760 LCD Screen Replacement Guide, Battery: step 1, image 2 of 3 Samsung S760 LCD Screen Replacement Guide, Battery: step 1, image 3 of 3
      • Placing your thumb on the battery cover, push outwards, away from the camera in the direction the arrow is pointing. If done correctly when it's completely unhooked, the latch will open.
      Ask FixBot
    2. Samsung S760 LCD Screen Replacement Guide: step 2, image 1 of 2 Samsung S760 LCD Screen Replacement Guide: step 2, image 2 of 2
      • Tip the camera as to gently slide the batteries out of the camera.
      Ask FixBot
    1. Samsung S760 LCD Screen Replacement Guide, LCD Screen: step 3, image 1 of 3 Samsung S760 LCD Screen Replacement Guide, LCD Screen: step 3, image 2 of 3 Samsung S760 LCD Screen Replacement Guide, LCD Screen: step 3, image 3 of 3
      • Locate and remove the six 4mm screws on the sides of the camera, using the Phillip Screwdriver #000 bit.
      • Screw dimensions refer to screw lengths.
      Ask FixBot
    2. Samsung S760 LCD Screen Replacement Guide: step 4, image 1 of 2 Samsung S760 LCD Screen Replacement Guide: step 4, image 2 of 2
      • Use the plastic opening tool to open pry open the back case, following alongside the edge of the case if need be.
      Ask FixBot
    3. Samsung S760 LCD Screen Replacement Guide: step 5, image 1 of 3 Samsung S760 LCD Screen Replacement Guide: step 5, image 2 of 3 Samsung S760 LCD Screen Replacement Guide: step 5, image 3 of 3
      • Under the LCD screen, remove the metal plate by removing the two 3mm screws holding it in place.
      Ask FixBot
    4. Samsung S760 LCD Screen Replacement Guide: step 6, image 1 of 2 Samsung S760 LCD Screen Replacement Guide: step 6, image 2 of 2
      • Use the plastic opening tool to gently lift the small gray clip covering the ribbon cable connection.
      • Carefully pull out the ribbon cable.
      Ask FixBot
3 other people completed this guide.
Author
with
Isaiah Weidmann
366 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 110
All Time: 1,880
