Samsung S760 Front and Back Case Replacement Guide
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
99
All Time:
1,117
Comments: 1
1 comment on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
How to remove the front and back cases of the device
Tools
    1. Samsung S760 Front and Back Case Replacement Guide, Battery: step 1, image 1 of 3 Samsung S760 Front and Back Case Replacement Guide, Battery: step 1, image 2 of 3 Samsung S760 Front and Back Case Replacement Guide, Battery: step 1, image 3 of 3
      • Placing your thumb on the battery cover, push outwards, away from the camera in the direction the arrow is pointing. If done correctly when it's completely unhooked, the latch will open.
      Ask FixBot
    2. Samsung S760 Front and Back Case Replacement Guide: step 2, image 1 of 2 Samsung S760 Front and Back Case Replacement Guide: step 2, image 2 of 2
      • Tip the camera as to gently slide the batteries out of the camera.
      Ask FixBot
    1. Samsung S760 Front and Back Case Replacement Guide, Front and Back Case: step 3, image 1 of 3 Samsung S760 Front and Back Case Replacement Guide, Front and Back Case: step 3, image 2 of 3 Samsung S760 Front and Back Case Replacement Guide, Front and Back Case: step 3, image 3 of 3
      • All screws in this camera are removed using the Phillip Screwdriver #000 bit. Also, all dimensions included refer to screw lengths.
      • Locate and remove the six 4mm screws on the sides of the camera.
      Ask FixBot
    2. Samsung S760 Front and Back Case Replacement Guide: step 4, image 1 of 2 Samsung S760 Front and Back Case Replacement Guide: step 4, image 2 of 2
      • Use the plastic opening tool to pry open the back case, following alongside the edge of the case if need be.
      Ask FixBot
    3. Samsung S760 Front and Back Case Replacement Guide: step 5, image 1 of 1
      • Once the back case is removed, use the plastic opening tool to gently pry off the front case.
      Ask FixBot
This will be used as a prerequisite to other guides. To reassemble your device, follow these instructions in reverse order.
4 other people completed this guide.
David Sepulveda
572 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 99
All Time: 1,117
