Up to 20% off select tools
Samsung S730 lcd screen replacement
Views: 2.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
109
All Time:
2,245
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
This repair is for a camera that has a bad LCD, as well as no flash, and no picture.
    1. Samsung S730 lcd screen replacement, LCD: step 1, image 1 of 3 Samsung S730 lcd screen replacement, LCD: step 1, image 2 of 3 Samsung S730 lcd screen replacement, LCD: step 1, image 3 of 3
      • Remove the batteries, memory card, and wrist strap if so equipped.
      • Remove the four screws on the bottom.
      • Remove the two screws on the right hand side
      Ask FixBot
    2. Samsung S730 lcd screen replacement: step 2, image 1 of 3 Samsung S730 lcd screen replacement: step 2, image 2 of 3 Samsung S730 lcd screen replacement: step 2, image 3 of 3
      • Remove the two screws from the left hand side
      • The screws are identical in length. No reason to keep them separate
      • Split the case from the battery compartment down. You can use an opening tool or your fingernails to accomplish that.
      Ask FixBot
    3. Samsung S730 lcd screen replacement: step 3, image 1 of 2 Samsung S730 lcd screen replacement: step 3, image 2 of 2
      • With the case split, you can see the LCD in its holder. The LCD is simply laid into the holder.
      • Gently remove the LCD from the holder and just flip it to the side. Do not remove it yet. You will have to loosen the clip on the connector. Use your fingernails to move it in the opposite direction from the LCD, this will open it up. Remove the LCD and replace with new one.
      Ask FixBot
2 other people completed this guide.
Author
with
oldturkey03
867,181 Reputation
123 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 109
All Time: 2,245
