Samsung Rogue Motherboard Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Samsung Rogue Motherboard Replacement, Motherboard: step 1, image 1 of 1
      • Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
      Ask FixBot
    2. Samsung Rogue Motherboard Replacement: step 2, image 1 of 1
      • Remove the five 3.4mm Philips screws securing the backing of the phone.
      Ask FixBot
    3. Samsung Rogue Motherboard Replacement: step 3, image 1 of 3 Samsung Rogue Motherboard Replacement: step 3, image 2 of 3 Samsung Rogue Motherboard Replacement: step 3, image 3 of 3
      • Use a plastic opening tool to carefully pry off the back cover.
      • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
      • Be careful to not drop the volume changing piece, for it can easily slip out.
      Ask FixBot
    4. Samsung Rogue Motherboard Replacement: step 4, image 1 of 1
      • Remove the two 3.45 mm Philips screws below the white sticker.
      Ask FixBot
    5. Samsung Rogue Motherboard Replacement: step 5, image 1 of 2 Samsung Rogue Motherboard Replacement: step 5, image 2 of 2
      • Carefully lift the motherboard up from the bottom edge.
      • The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
      Ask FixBot
    6. Samsung Rogue Motherboard Replacement: step 6, image 1 of 2 Samsung Rogue Motherboard Replacement: step 6, image 2 of 2
      • Use a plastic opening tool to disconnect the film from the motherboard.
      Ask FixBot
Viktoria Mikoultchik
25 Reputation
7 Guides authored
Cal Poly, Team 7-32, Maness Spring 2012 Member of Cal Poly, Team 7-32, Maness Spring 2012
CPSU-MANESS-S12S7G32
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 436
