Up to 20% off select tools
Samsung Rogue Battery Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
5
Past 30 Days:
30
All Time:
858
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide will show a step-by-step procedure for replacing the battery in your Samsung Rogue. Replacing the battery on the Samsung Rogue requires minimum disassembly.
    1. Samsung Rogue Battery Replacement, Battery: step 1, image 1 of 2 Samsung Rogue Battery Replacement, Battery: step 1, image 2 of 2
      • Before disassembling your Samsung Rogue, make sure it is powered off.
      • With your thumbs, push down on the back cover of your phone and slide it away from the camera.
      Ask FixBot
    2. Samsung Rogue Battery Replacement: step 2, image 1 of 2 Samsung Rogue Battery Replacement: step 2, image 2 of 2
      • You can now remove the battery by prying it up with your finger.
      Ask FixBot
Author
with
Viktoria Mikoultchik
25 Reputation
7 Guides authored
Cal Poly, Team 7-32, Maness Spring 2012 Member of Cal Poly, Team 7-32, Maness Spring 2012
CPSU-MANESS-S12S7G32
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 30
All Time: 858
