Samsung Refrigerator Fuse Block Replacement
Views: 5.2K
View statistics:
Past 24 Hours:
7
Past 7 Days:
46
Past 30 Days:
201
All Time:
5,218
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 20 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide shows how to remove and replace the fuse block or fuse board in your Samsung refrigerator.
The fuse block contains a number of fuses soldered on a circuit board and is made to be replaced as a whole unit. If your refrigerator doesn't power on at all, you may need to replace the fuse block.
This guide will work for most Samsung Refrigerators. This guide is based on a model RF28R7201SG Refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
Tools
    1. Samsung Refrigerator Fuse Block Replacement, Unplug your refrigerator: step 1, image 1 of 1
      • Unplug your refrigerator before you begin your repair.
      • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
      • Condenser fan motor
      • Compressor motor and thermal overload device
      • Water supply valve assembly
      Ask FixBot
    1. Samsung Refrigerator Fuse Block Replacement, Remove the board access panel: step 2, image 1 of 1
      • Remove the screws securing the board access panel to the back of the refrigerator.
      Ask FixBot
    2. Samsung Refrigerator Fuse Block Replacement: step 3, image 1 of 2 Samsung Refrigerator Fuse Block Replacement: step 3, image 2 of 2
      • Remove the board access panel.
      Ask FixBot
    1. Samsung Refrigerator Fuse Block Replacement, Remove the fuse block: step 4, image 1 of 3 Samsung Refrigerator Fuse Block Replacement, Remove the fuse block: step 4, image 2 of 3 Samsung Refrigerator Fuse Block Replacement, Remove the fuse block: step 4, image 3 of 3
      • Squeeze the wide sides of the red connector to unlatch it from the fuse block.
      • Pull to disconnect the connector.
      • Repeat the procedure to disconnect the blue connector.
      • During reassembly, make sure the connectors lock in place. If they don't, you may need to flip their orientation.
      Ask FixBot
    2. Samsung Refrigerator Fuse Block Replacement: step 5, image 1 of 3 Samsung Refrigerator Fuse Block Replacement: step 5, image 2 of 3 Samsung Refrigerator Fuse Block Replacement: step 5, image 3 of 3
      • Use your fingers to pry and release the black plastic clip holding the left edge of the fuse block.
      • Lift out and remove the fuse block.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers Community for help.
nicO
15,990 Reputation
88 Guides authored
Team Vulcan Member of Team Vulcan
Staff
6 Members
1,884 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 46
Past 30 Days: 201
All Time: 5,218
