Up to 20% off select tools
Samsung Refrigerator Control Panel Wiring Fix
Views: 5.6K
View statistics:
Past 24 Hours:
6
Past 7 Days:
72
Past 30 Days:
270
All Time:
5,624
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Community-Contributed Guide
    1. Samsung Refrigerator Control Panel Wiring Fix, Description of the problem: step 1, image 1 of 2 Samsung Refrigerator Control Panel Wiring Fix, Description of the problem: step 1, image 2 of 2
      • This guide applies when the control panel of your Samsung fridge is starting to act up.
      • In my case it was unresponsive to some buttons and the display showed incomplete digits
      • This might be relevant for a number of models.
      Ask FixBot
    2. Samsung Refrigerator Control Panel Wiring Fix, Control panel: step 2, image 1 of 1
      • In you want, you can pop out the control panel by putting a knife behind it.
      • This is not necessary but helps to identify the connections. In my case, pressing the top button connected connector pin 1 to ground (pin7) via a 10k resistor.
      Ask FixBot
    3. Samsung Refrigerator Control Panel Wiring Fix, Wiring issue: step 3, image 1 of 1
      • The problem in my case was the wiring loom that runs through the top hinge of the fridge door.
      • As you can see it is broken in multiple places. Its design is a bit poor as the plastic in the hinge is too sharp.
      • You can fix it by soldering and covering the connections in shrink tubing.
      Ask FixBot
2 other people completed this guide.
Author
with
Mark
543 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 72
Past 30 Days: 270
All Time: 5,624
