Up to 20% off select tools
Samsung Refrigerator Control Panel Replacement
Views: 6.3K
View statistics:
Past 24 Hours:
19
Past 7 Days:
117
Past 30 Days:
498
All Time:
6,309
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Moderate
Tools
  • Spudger
    4.9
  • 1/4" Flathead Screwdriver
    $14.41 $16.95
    4.6
    Optional
Introduction
Go to step 1 ↓
This guide shows how to remove and replace the control panel in your Samsung refrigerator.
The control panel contains the buttons to change the refrigerator settings, as well as a display for current settings. The panel can become damaged and inoperative from prolonged moisture exposure.
This guide will work for most Samsung Refrigerators . This guide is based on a model RF28R7201SG Refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
    1. Samsung Refrigerator Control Panel Replacement, Unplug your refrigerator: step 1, image 1 of 1
      • Unplug your refrigerator before you begin your repair.
      • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
      • Condenser fan motor
      • Compressor motor and thermal overload device
      • Water supply valve assembly
      Ask FixBot
    1. Samsung Refrigerator Control Panel Replacement, Open the refrigerator doors: step 2, image 1 of 2 Samsung Refrigerator Control Panel Replacement, Open the refrigerator doors: step 2, image 2 of 2
      • Open both French doors for the refrigerator compartment.
      Ask FixBot
    1. Samsung Refrigerator Control Panel Replacement, Loosen the control panel: step 3, image 1 of 3 Samsung Refrigerator Control Panel Replacement, Loosen the control panel: step 3, image 2 of 3 Samsung Refrigerator Control Panel Replacement, Loosen the control panel: step 3, image 3 of 3
      • The control panel has plastic clips around its perimeter that secure it to the refrigerator wall.
      • Insert a spudger into the seam along the right edge of the control panel.
      • You can also use a flathead screwdriver, but be careful not to let the screwdriver slip, or you'll scratch your refrigerator surface.
      • Press the spudger in firmly and pry to loosen the panel.
      • Use your spudger to slide and pry around the control panel to loosen it from the refrigerator wall.
      Ask FixBot
    2. Samsung Refrigerator Control Panel Replacement: step 4, image 1 of 1
      • Flip the control panel over to reveal the cable connector.
      Ask FixBot
    3. Samsung Refrigerator Control Panel Replacement: step 5, image 1 of 2 Samsung Refrigerator Control Panel Replacement: step 5, image 2 of 2
      • Use your fingers to slide the cable connector out of its socket.
      Ask FixBot
    4. Samsung Refrigerator Control Panel Replacement, Remove the control panel: step 6, image 1 of 1
      • Remove the control panel.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers Community for help.
Author
with
nicO
15,990 Reputation
88 Guides authored
Team Vulcan Member of Team Vulcan
Staff
6 Members
1,884 Guides authored
0 Guide Comments
Past 24 Hours: 19
Past 7 Days: 117
Past 30 Days: 498
All Time: 6,309
