Up to 20% off select tools
Samsung Refrigerator Control Board Replacement
Views: 11K
View statistics:
Past 24 Hours:
17
Past 7 Days:
159
Past 30 Days:
689
All Time:
11,199
Comments: 6
1 comment on steps, 5 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide shows how to remove and replace the control board in your Samsung refrigerator.
The control board controls the refrigerator's functions. It also has a DC power board built into it. If your refrigerator turns on but doesn't function properly, check the components related to the function first. Replace the control board only after you've verified the other components.
This guide will work for most Samsung Refrigerators . This guide is based on a model RF28R7201SG Refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
    1. Samsung Refrigerator Control Board Replacement, Unplug your refrigerator: step 1, image 1 of 1
      • Unplug your refrigerator before you begin your repair.
      • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
      • Condenser fan motor
      • Compressor motor and thermal overload device
      • Water supply valve assembly
      Ask FixBot
    1. Samsung Refrigerator Control Board Replacement, Remove the board access panel: step 2, image 1 of 1
      • Remove the screws securing the board access panel to the back of the refrigerator.
      Ask FixBot
    2. Samsung Refrigerator Control Board Replacement: step 3, image 1 of 2 Samsung Refrigerator Control Board Replacement: step 3, image 2 of 2
      • Remove the board access panel.
      Ask FixBot
    1. Samsung Refrigerator Control Board Replacement, Reassembly information: step 4, image 1 of 2 Samsung Refrigerator Control Board Replacement, Reassembly information: step 4, image 2 of 2
      • Note the locations and number of the connectors on the control board, and photograph them or draw a diagram. This example control board has nine wire connectors:
      • Three connectors along the top edge
      • One connector along the right edge
      • One connector along the bottom edge
      • Four connectors along the left edge
      • During reassembly, use your diagram or the photo you took (like the second image here) to make sure you've reconnected all of the connectors.
      Ask FixBot
    2. Samsung Refrigerator Control Board Replacement, Remove the control board: step 5, image 1 of 2 Samsung Refrigerator Control Board Replacement, Remove the control board: step 5, image 2 of 2
      • Pull and disconnect each of the connectors from the control board.
      • Some connectors may have a locking tab. Squeeze the wide sides of the connector to unlock it, then pull to disconnect it.
      • Move the wires away from the control board so it can swing out of its recess.
      Ask FixBot
    3. Samsung Refrigerator Control Board Replacement: step 6, image 1 of 3 Samsung Refrigerator Control Board Replacement: step 6, image 2 of 3 Samsung Refrigerator Control Board Replacement: step 6, image 3 of 3
      • Use your fingers to push up the plastic lip securing the top edge of the control board to the refrigerator.
      • Swing the control board out and remove it.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers Community for help.
3 other people completed this guide.
Author
with
Bill Gilbert
41,156 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
5 Guide Comments
My tempura in my new refrigerator isn’t working right , I bought earlier this year
Carolyn whittaker - Reply Share
Is this Samsung
Do you have a phone number
Samsung fridge- after changing a water filter, bottom drawer freezer stopped making ice.
It is set for 0 but no ice. I bought this fridge last year.
Sewell Nikki - Reply Share
My refrigerator light is on but the comppresor is not working and anytime I on it is not piping sounds again
Asiafa - Reply Share
Past 24 Hours: 17
Past 7 Days: 159
Past 30 Days: 689
All Time: 11,199
