Samsung Rant Rear Case Replacement
    1. Samsung Rant Rear Case Replacement, Back Cover: step 1, image 1 of 1
      • Turn the phone over in the palm of your hand, with the screen facing down.
      • While grasping the bottom part of the phone with one hand, use your thumb to push the release button at the end of the phone.
      • This will release the back plate latch; then lift the back plate up and out toward the other end of the phone.
      • You should now be able to lift the plate completely off of the phone.
      Ask FixBot
    1. Samsung Rant Rear Case Replacement, Rear Case: step 2, image 1 of 1
      • Use a Phillips #00 screwdriver to loosen and remove all 3 screws.
      Ask FixBot
    2. Samsung Rant Rear Case Replacement: step 3, image 1 of 1
      • Gently separate the rear case from the front case.
      Ask FixBot
Denise Cooper
31 Reputation
3 Guides authored
James Madison, Team 1-6, Allen Fall 2011 Member of James Madison, Team 1-6, Allen Fall 2011
JMU-ALLEN-F11S1G6
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 25
All Time: 1,476
