Up to 20% off select tools
Samsung Rant Keypad Replacement
Views: 2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
3
Past 30 Days:
17
All Time:
2,016
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 7 - 10 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Missing Steps
Oops! This guide is currently missing one or more important steps.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
In order to access the keypad, you must first remove the back cover, battery and rear case from the cell phone.
    1. Samsung Rant Keypad Replacement, Back Cover: step 1, image 1 of 1
      • Turn the phone over in the palm of your hand, with the screen facing down.
      • While grasping the bottom part of the phone with one hand, use your thumb to push the release button at the end of the phone.
      • This will release the back plate latch; then lift the back plate up and out toward the other end of the phone.
      • You should now be able to lift the plate completely off of the phone.
      Ask FixBot
    1. Samsung Rant Keypad Replacement, Battery: step 2, image 1 of 1
      • Carefully remove the battery from the phone.
      Ask FixBot
    1. Samsung Rant Keypad Replacement, Rear Case: step 3, image 1 of 1
      • Use a Phillips #00 screwdriver to loosen and remove all 3 screws.
      Ask FixBot
    2. Samsung Rant Keypad Replacement: step 4, image 1 of 1
      • Gently separate the rear case from the front case.
      Ask FixBot
    1. Samsung Rant Keypad Replacement, Keypad: step 5, image 1 of 2 Samsung Rant Keypad Replacement, Keypad: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Using a pair of tweezers, grip the keypad gently.
      • Lift the keypad out of the phone and replace it (if necessary).
      Ask FixBot
Author
with
Denise Cooper
31 Reputation
3 Guides authored
James Madison, Team 1-6, Allen Fall 2011 Member of James Madison, Team 1-6, Allen Fall 2011
JMU-ALLEN-F11S1G6
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 17
All Time: 2,016
