Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement
    1. Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement, Wireless Setup Button and USB Module: step 1, image 1 of 3 Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement, Wireless Setup Button and USB Module: step 1, image 2 of 3 Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement, Wireless Setup Button and USB Module: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • Flip the device so that the bottom of the device is facing you. Remove these feet with a pair of tweezers.
      • Remove the four 10mm long screws with the Phillips #1 screwdriver.
      Ask FixBot
    2. Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement: step 2, image 1 of 1
      • Remove the bottom shell from the speaker.
      Ask FixBot
    3. Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement: step 3, image 1 of 2 Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement: step 3, image 2 of 2
      • Remove the connector from the board by pressing down on the center tab while nudging the connector away with a spudger.
      • Be careful not to pull directly on the wires or apply too much pressure, or you risk breaking the connector.
      Ask FixBot
    4. Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement: step 4, image 1 of 1
      • Remove the two 10mm long screws from the board utilizing the Phillips #1 screwdriver.
      Ask FixBot
    5. Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement: step 5, image 1 of 1
      • Use a spudger to press the plastic tab away from the board until the board pops up.
      • Remove the board with the USB module from the device.
      Ask FixBot
Fadi Alzammar
782 Reputation
5 Guides authored
Cal Poly, Team S25-G18, Maness Spring 2018 Member of Cal Poly, Team S25-G18, Maness Spring 2018
CPSU-MANESS-S18S25G18
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 23
All Time: 568
