Up to 20% off select tools
Samsung Radiant360 R3 Wireless Module Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
68
All Time:
792
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 25 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will take you through the process of removing the bottom of the speaker, seperating the shell of the enclosure, and accessing the wireless module for removal.
    1. Samsung Radiant360 R3 Wireless Module Replacement, Wireless Setup Button and USB Module: step 1, image 1 of 3 Samsung Radiant360 R3 Wireless Module Replacement, Wireless Setup Button and USB Module: step 1, image 2 of 3 Samsung Radiant360 R3 Wireless Module Replacement, Wireless Setup Button and USB Module: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • Flip the device so that the bottom of the device is facing you. Remove these feet with a pair of tweezers.
      • Remove the four 10mm long screws with the Phillips #1 screwdriver.
      Ask FixBot
    2. Samsung Radiant360 R3 Wireless Module Replacement: step 2, image 1 of 1
      • Remove the bottom shell from the speaker.
      Ask FixBot
    3. Samsung Radiant360 R3 Wireless Module Replacement: step 3, image 1 of 2 Samsung Radiant360 R3 Wireless Module Replacement: step 3, image 2 of 2
      • Remove the connector from the board by pressing down on the center tab while nudging the connector away with a spudger.
      • Be careful not to pull directly on the wires or apply too much pressure, or you risk breaking the connector.
      Ask FixBot
    4. Samsung Radiant360 R3 Wireless Module Replacement: step 4, image 1 of 1
      • Remove the two 10mm long screws from the board utilizing the Phillips #1 screwdriver.
      Ask FixBot
    5. Samsung Radiant360 R3 Wireless Module Replacement: step 5, image 1 of 1
      • Use a spudger to press the plastic tab away from the board until the board pops up.
      • Remove the board with the USB module from the device.
      Ask FixBot
    1. Samsung Radiant360 R3 Wireless Module Replacement, Wireless Module: step 6, image 1 of 2 Samsung Radiant360 R3 Wireless Module Replacement, Wireless Module: step 6, image 2 of 2
      • Remove the two 12mm long screws with the Phillips #1 screwdriver.
      • Unplug white plug connected to the green circuit board.
      Ask FixBot
    2. Samsung Radiant360 R3 Wireless Module Replacement: step 7, image 1 of 2 Samsung Radiant360 R3 Wireless Module Replacement: step 7, image 2 of 2
      • Remove the four 12mm long screws with the Phillips #1 screwdriver.
      • Remove the cover, and slide the cord through the hole.
      Ask FixBot
    3. Samsung Radiant360 R3 Wireless Module Replacement: step 8, image 1 of 3 Samsung Radiant360 R3 Wireless Module Replacement: step 8, image 2 of 3 Samsung Radiant360 R3 Wireless Module Replacement: step 8, image 3 of 3
      Buy
      • Remove rubber covers covering the screws with pair of tweezers.
      • Remove the six 12mm screws that are under the rubber covers with the Phillips #1 screwdriver.
      Ask FixBot
    4. Samsung Radiant360 R3 Wireless Module Replacement: step 9, image 1 of 1
      • Remove the unscrewed cover as much as possible.
      • It is very difficult to get plugs at the end of the cord through the cover without breaking, so just slide to the edge.
      Ask FixBot
    5. Samsung Radiant360 R3 Wireless Module Replacement: step 10, image 1 of 3 Samsung Radiant360 R3 Wireless Module Replacement: step 10, image 2 of 3 Samsung Radiant360 R3 Wireless Module Replacement: step 10, image 3 of 3
      • Push the body out through the outer shell of device.
      • Carefully push the ring attached to the cable through the shell.
      Ask FixBot
    6. Samsung Radiant360 R3 Wireless Module Replacement: step 11, image 1 of 3 Samsung Radiant360 R3 Wireless Module Replacement: step 11, image 2 of 3 Samsung Radiant360 R3 Wireless Module Replacement: step 11, image 3 of 3
      • Remove the eight 12mm long screws around the body with the Phillips #1 screwdriver.
      Ask FixBot
    7. Samsung Radiant360 R3 Wireless Module Replacement: step 12, image 1 of 2 Samsung Radiant360 R3 Wireless Module Replacement: step 12, image 2 of 2
      • Pry the two halves of the body open using a metal spudger.
      Ask FixBot
    8. Samsung Radiant360 R3 Wireless Module Replacement: step 13, image 1 of 3 Samsung Radiant360 R3 Wireless Module Replacement: step 13, image 2 of 3 Samsung Radiant360 R3 Wireless Module Replacement: step 13, image 3 of 3
      • Remove the plugs located topmost right and closest to the bottom in picture.
      Ask FixBot
    9. Samsung Radiant360 R3 Wireless Module Replacement: step 14, image 1 of 1
      • Remove the four 12mm long screws with the Phillips #1 screwdriver .
      Ask FixBot
    10. Samsung Radiant360 R3 Wireless Module Replacement: step 15, image 1 of 1
      • Unscrew the four 8mm screws on the side of the motherboard with the Phillips #1 screwdriver .
      • Remove the Wireless Module from the device.
      Ask FixBot
Author
with
Fadi Alzammar
782 Reputation
5 Guides authored
Cal Poly, Team S25-G18, Maness Spring 2018 Member of Cal Poly, Team S25-G18, Maness Spring 2018
CPSU-MANESS-S18S25G18
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 68
All Time: 792
